Rust around fuel tank filler neck
   / Rust around fuel tank filler neck #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
I have a 2012 model John Deere 5093E. There is significant light rust around the filler neck, chain that attaches to the screw on fuel cap and a small spring in the cap..Any idea what could account for this?
   / Rust around fuel tank filler neck #2
Moisture in your fuel
   / Rust around fuel tank filler neck #3
Too much rain or too many wash jobs.
   / Rust around fuel tank filler neck #4
Salt spray if out near a highway during winter in MN.. possibly.
Probably just condensation but I've never seen it this bad on such a new model (2012) However, the tractor set for a year without use before I bought it and I suspect the fuel tank was near empty..
   / Rust around fuel tank filler neck #6
:D Not likely salt in TX unless on the gulf maybe.
   / Rust around fuel tank filler neck #7
I had this issue on 2012 model . Replaced cap under warranty. I removed chain as it appeared to be source of most rust. I didn't like chain anyway. I turn my cap facing up on fender when refueling
   / Rust around fuel tank filler neck #8
I have a 2014 5065e with the same issue, looked through john deere parts and the threads in tank did not have a part number or breakout. Does anyone know where to get a replacement thread insert.
   / Rust around fuel tank filler neck #9
I looked at my box that parts came in. The black plastic cap is part number AL 113086. I have another parts bag with part number L 80418 on it. I think that is the threaded filler neck. There is a rubber o-ring under filler neck (which threads into plastic tank nozzle). The o-ring seals between metal neck and plastic tank. My tractor is a 2012 5065e. I doubt the tank changed. The o-ring is part number L 112337.
Mine is also a 2012 model..I think I too will remove the chain..It's about to rust off anyway :)
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A53843)
2013 KENWORTH T800...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
CRESCENT  MANIFOLD TRAILER (A53843)
CRESCENT MANIFOLD...
