Rushy's box blade project (4 ft, hinged back)
   / Rushy's box blade project (4 ft, hinged back) #1
Rushy11
Germany/NZ
Kubota1500
Hi,
I'm just making up a draft for a box blade. I wanna pull this 4ft box blade with my 19hp Kubota B1500. Fortunately i found Google Sketchup, as this is a really easy way to make up a few drafts on the computer.
I'm happy to hear your critic and maybe a few suggestion how to improve a few things! :)
Cheers
Rushy
   / Rushy's box blade project (4 ft, hinged back) #2
Welcome to TBN, Rushy.
That looks plenty beefy for 19hp!
How are you going to mount the pins for the 3 point hitch?
Looks great - I'll have to give Sketchup a try.
   / Rushy's box blade project (4 ft, hinged back) #3
looks like a "depth adjuster" may be needed....
   / Rushy's box blade project (4 ft, hinged back) #4
The blades on most scapers are curved. Are yours going to be straight?
@Baby Grand
That's an triangle for the european quick hitch like this here Weiste-Dreieck_am_Fronthubwerk_2.jpg
@Dave
I haven't put in the bolts in yet for the scarifier, if you mean that
@jel 1988
I'm not too sure about that, an folded blade is much easier to make for me. Maybe i do an curved blade. Not to sure, if i can find an engineer who can curve me a sheet.
   / Rushy's box blade project (4 ft, hinged back) #6
If I was going to build a box blade I would design it so that at some point the rippers could be made to be raised/lowered with hydraulics...
Hi,
i just did some calculations about the weight...
without any welds and bolts the box blade will have a gross weight of 153kg (about 340 pound). I think, that should give it enough downforce?:)
@ /pine
Yeah, i really like that idea, but it seems to be a bit complicated.
   / Rushy's box blade project (4 ft, hinged back) #9
Nice looking box blade. I think the straight blade will work fine, it's the angle that does the cutting anyway. I'm equally impressed with your google sketchup skills!
   / Rushy's box blade project (4 ft, hinged back) #10
@Baby Grand
@Dave
I was thinking of hydraulically raised and lowered wheels to control the depth of cut.....
Works a lot better than 3 pt. hitch adjustments, especially on "rough" terrain.... the wheels are usually behind the blade.... OR shoes that adjust to increase/reduce depth of cut...
Looks like the blades will always be set at the current depth of cut.... I could be missing something....
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
2007 Chrysler Pacifica SUV (A51694)
2007 Chrysler...
TAKEUCHI TL230 SERIES 2 SKID STEER (A51246)
TAKEUCHI TL230...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
(2) ROW PLANTER W/ COLE PLANTERS (A51247)
(2) ROW PLANTER W/...
2023 LMC M40018 LOT IDENTIFIER 163 (A53084)
2023 LMC M40018...
