ultrarunner
Epic Contributor
- Joined
- Apr 6, 2004
- Messages
- 24,458
- Tractor
- Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
My upgrade to AT&T U-verse for DSL for the 6MB/sec service has been a real pain in the .... The net result so far is I am still below 3MB down load and my upload speeds may be a little slower than when I started.
Twice the installation technicians said something was not ready on the line or central switch. Each time I had to spend 30-60min on the phone to schedule the next hookup appointment.
During the first attempt to install the service upgrade they disconnected the existing AT&T DSL service and when I called for the next appointment they said it would be about four days away. I had to ask them to turn back on the old service. At least they were able to turn that back on the same day. That took four calls with AT&T.
Finally the updated service with new gateway (Motorola NVG510) was installed. The evening after the installation I was experiencing on and off internet outages with message from router about the quality of the line and many web pages would not load. So I made sure it was not my home wiring by connecting the gateway to the terminal box on my house at the end of the phone company's line. Then I call tech support.
During the call the tech said my line did not test well and I was far from the central hub and he would try changing some settings in the gateway. After he changed the settings and I reset the gateway the web pages did not hang. Then I ran a few speed tests with the tech on the line he admitted his fix was to lower my DSL speed down to 3MB max.
So a great deal of pain for no gain, and maybe a step back in speed
A friend in the Oakland Hills had the same issues... eventually they noted his account and he has the fastest residential service at the Central Office because by the time it gets to his house it is only the speed which he is paying for.
There are tweeks that can be done if you get the right person...
The senior field tech says marketing does this to them all the time... they make promises that may or may not be possible...
Same at my Oakland home... ended up having to run a new line quite a distance because the 1950 line was not up to DSL spec.
Sqeaky Wheel gets the grease.
