runs and then quits
   / runs and then quits #1
r porter
arkansas
workmaster 45
workmaster 45 quit last night. installed new fuel filter right away and then it would run for 3 seconds and stop. finally it started and with throttle wide open it would idle. eventually it fired off and i made it to the barn.
this morning i hit the key and it ran for a minute and i went wide open for 10 seconds then it quit. i drained all the fuel out and put new fuel in. also removed the sediment bowl and could not see water. or dirt. finally i got the bleeder tube on top of the pump removed and some fuel was squirting out about an inch high. but it still will only fire for a second or so. when it fires i have fuel out of the injector lines but if it does not fire there is no fuel out of the line at the injectors.
if i crank with the starter i can not get fuel out of the line at the injectors.
my gut says it is not the pump but i am out of options. is there anything on the pump to be intermittent? with no fuel when i crank, it cant start.
   / runs and then quits #2
My NH Workmaster 55 had a similar problem. There is a card on the dashpanel that controls the fuel solenoid (I actually replaced mine before finding the fix). The card can wear its contacts over time and the tractor will act like you've just shut off the key. Look down the forum, my post is there. The card is cheap--$8-15 I think. For me, the bracket holding it to the dashpanel wasn't all the way tight and probably added to the wiggling that wore down the contacts.
   / runs and then quits #3
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
