Chipper Runout on chipper shredder sheave
   / Runout on chipper shredder sheave #1
JackyJ
Central Indiana
Kubota BX1870
I've just acquired a new MacKissic PTO chipper shredder and I'm addressing several concerns with the manufacturer. One is a distinct wobble in the sheave attached to the pto shaft. The sheave is 14" in diameter and I measure the runout at about 0.1" You can see it in the video below where the tractor is idling.
What is a typical runout tolerance for something like this?
Jack
   / Runout on chipper shredder sheave #2
Take a rubber hammer and smack it on the high spot, rinse, lather & repeat. It is a lot of run out on something new but nothing to lose sleep over.
   / Runout on chipper shredder sheave #3
Jack
It looks like the pulley is not seated aganist the shaft collar that I see on the right side? Do those bolts need to be tightened? Ken Sweet
I did check those and everything is snug/tight. Seems to me that either the drive shaft itself has some runout, or the sheave is slightly warped. Maybe a bit of both, but since the two are keyed together I can't change their relative orientations to see if that would help.
   / Runout on chipper shredder sheave #5
if the hub bolts go thru the pulley, can you tighten/loosen to affect the runout? Ken Sweet
That's a good idea--I checked to make sure everything was snug, but maybe I can make some adjustment there. Thanks for the suggestions--I will give it a try!
   / Runout on chipper shredder sheave #7
Two piece sheaves with a tapered center hub are vulnerable to un-equal tightening of the bolts. You need to use a torque wrench to assure even tightening. I am surprised to see only one belt. My 6" chipper had 4 belt sheaves. The length of the wider hub helps prevent the distortion you can get with single belt arrays. Unless you hipper is in the 2" range you will replace a lot of belts and be adjusting them a lot if used much. Belts too tight can also distort those single belt assemblies. Do you have any specs on the chipper like US made stuff comes with? A belt asnd sheave supplier can provide you with torque ratings, new ones come with that info. A dial indicator can be a good diagnostic tool for this also. Shaft end play came come into the equation also as well as worn/imperfect bearings. A bearing pillow block not bolted down tight also comes into mind. Never know what gets past factory QA.
Ron
Thanks Ron--this sort of hub/bushing is new to me, and it looks like I need to get some details on it. I found some installation info on Browning hubs with torque specs, but the parts list on my chipper doesn't tell me any details on which hub I have. Hopefully the chipper manufacturer can help me out with this and it is just an adjustment issue--I'm waiting to hear back from their service manager who is out of town this week.
7-NEW INJECTION HARNESS (A55745)
7-NEW INJECTION...
GRILL (A55745)
GRILL (A55745)
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
