Running Sabre Samurai Cutter from 3rd Function Valve
   / Running Sabre Samurai Cutter from 3rd Function Valve #1
rturner98
Loxley, AL
Kubota L3800HST Kubota M6060HDC Kubota KX040-4
Is anyone running a Samurai Cutter from the 3rd function valve?
Did you plumb it in any special way, for example; dedicated return line to the tank, flow control valve, check valves?
   / Running Sabre Samurai Cutter from 3rd Function Valve #2
Connect it normally with both lines to the third function.
If it happens to jam, you need a way to reverse it, which a dedicated tank line won't allow.
   / Running Sabre Samurai Cutter from 3rd Function Valve #3
Do they specify a minimum diameter for the hoses?
Or a minimum flow in gallons per minute?
   / Running Sabre Samurai Cutter from 3rd Function Valve #4
Low flow for this device. Manufacturer recommends flow restriction to a point where user can see teeth moving when engaged. Guessing 2 gpm.
   / Running Sabre Samurai Cutter from 3rd Function Valve #5
It should work if connected normally. No return line should be necessary. Keep in mind that 3rd function valves are primarily designed to operate hydraulic cylinders. They can overheat if used with a hydraulic motor for long periods.
Thanks for the comments everyone. Overheating the hydrualic valve is something I have not thought about but need to watch.
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
2011 Volvo Semi Truck (NOT RUNNING)(TITLE) (A50774)
2011 Volvo Semi...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A50323)
2017 Mack GU713...
Guard Rail Joints (A51692)
Guard Rail Joints...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
NEW Woods 6ft Finish Mower (A52748)
NEW Woods 6ft...
