Running Power to Detached Garage
   / Running Power to Detached Garage #41
I disagree with running Cat5 or any other internet type cable to a barn. What would you use it for? I use my phone if I need to look something up right away, but if I'm doing something and I get lost, I'll walk back to my main computer and search for a youtube video of how to do it. I really don't want a computer in my shop.
IP cameras and alarms?
   / Running Power to Detached Garage #42
When I built my detached a few years ago I ran 3- 2" conduits. One for power, one for low voltage like cat6 for WiFi and cameras and another yet to be used in case I want to put solar on south facing roof to run power back to house. Not sure I'd do all 3 in today's prices but sure nice to have. I also had them rough in LP when I decide to add heat. When you're Building is the time to do all that as you guys well know.
   / Running Power to Detached Garage #43
1 or 2 larger for power
2 or 3 smaller for low voltage
Water
Gas
If you're doing a concrete floor and foundation in the outbuilding, add a drain line that can be used later for a sink.
Yes, the price of materials is stupid, but it'll drop again before too long hopefully.
But what will it cost in time and aggravation if this run would be under future landscaping or paved areas? Five years down the road, do you want to dig up a rose bed you've worked hard to establish? Personally, I try to know where underground runs are and avoid planting over them, but that isn't always possible.
   / Running Power to Detached Garage #44
I forgot about the music. I log into Pandora when tooling about the shop. Music in shop is nice.
I also use my iPad for doing inventory in shop (generator repair parts inventory). Having wifi in shop does come in handy. Never thought about it when I built shop in 1996.
Yep. I'm not a big sports fan by any means. However, there's something about being out in the yard and garage on a sunny crisp fall day listening to a Notre Dame football game while raking leaves or working on things.
   / Running Power to Detached Garage #45
Another observance:
How many times here on TBN do people post questions/problems concerning WIFI in outbuildings compared to people reporting problems with their hard-wired connections?
My wife has been working from home for over a year. Her company laptop has issues with our WIFI dropping out fairly frequently. It's due to the age of our ISP provided WIFI and the location in the house she's chosen to use as her office.
Solution? I ran a Cat5 cable from the basement to her "office", crimped on a couple ends, plugged the laptop directly into the ISP router and she's been good ever since.
WIFI is great for convenience. However, in my decades of IT experience at my old job as well as my personal life and dealing with it for the entire family and group of friends, I've had 99.9% reliability with hard wire and the WIFI keeps burping. :sick:
   / Running Power to Detached Garage #46
My service (200 amp) is direct buried to my shop and the gas line is also in the same trench.
Bad news having both electric/gas in the same trench if you have problems.Hope they are padded(with sand) between both..(n)
   / Running Power to Detached Garage #47
The wifi extender I am using in my shop has been in use for 2 trouble free years so far. The only reason I went wifi is cause I damaged my underground cat5 wire. Main issue is it was run after I ran all underground. Rest of my stuff is 5 feet deep for water, 3 feet deep for gas and elect. The cat5 was maybe 18” when run years later. Fencing horse pasture wrecked it. Instead of trying to find and repair, I went wireless.
very happy with the system I chose.
my entire house is wired in parallel cat5 ethernet .... don’t use any of it. My last holdout was my office printer. When it died I purchased an hp that has wifi. So now I can also print from my iPad and phones.
I have a ups backup on my main wifi unit. I generally have to replace wifi unit every 4-5 years it seams, but there pretty much trouble free. But I do dread the day I have to replace the wifi router. Always a nightmare.
i didnt think I needed cat5 in shop back in 96 is all. Things change.
   / Running Power to Detached Garage #48
In 2018, I put up a new pole barn on the site of a 1881 post and beam barn that my great great grandad had built. In 1980, my grandad ran a direct bury line to that old barn, from a 15 amp breaker in the basement of the house, 200 ft away. That line went only to a single 120 volt outlet on the corner of the old barn. The only thing I remember us using it for, was to plug in the motor on a conveyer, for loading hay bales into the loft.
When I dismantled the old barn, I flipped the breaker off and took off the outlet. I ran a 2" conduit to the basement, while I was doing the site work for the new pole barn. Someday, if I ever have need for more power, I will run lines thru that.
In the mean time, grandpa's old direct bury 15 amp line, from 1980, is working very well. I use (3) 4 ft LED lights, a garage door opener, drill press, table saw, band saw, 2 hp shop vac, small air compressor, and a few other power tools, with no issues.
To the current home, I have 400 amps of power going to the panel. Which splits the power to 200 amps to the current home and then 200 amps will go to the future home.
Then from the future home panel, I will run PVC conduit with copper wire to the detached garage which will have a 100 amp sub panel inside the garage. 100 Amp Sub Panel
How large of copper wire should I use from the current home to the future home?
How about the future home to the garage?
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A54865)
2012 Mitsubishi...
2017 GMC SIERRA 1500 (A55745)
2017 GMC SIERRA...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
L- Shaped Fuel Tank with Pump (A54865)
L- Shaped Fuel...
