Running Plumbing Vent Through Wall & Studor AIV's
   / Running Plumbing Vent Through Wall & Studor AIV's #1
Pettrix
Platinum Member
High Desert Southwest
On my new house build, I had a nice and expensive standing seam metal roof installed. Talking with plumber and building inspector, they said I can run Studor AIV's on some of my plumbing vent stacks and I only require ONE outside plumbing stack vent. That outside vent can be through a wall that isn't near a window.
I know the best and most maintenance free plumbing vent stack is through the roof. Studor AIV's require replacement (7-10 years) and they are easy to installer and not expensive. I am not a fan of roof penetrations as they are always the first to leak. The wall vent is just like a roof vent and don't require maintenance. Anyone here with Studor AIV's and if they like or dislike them?
   / Running Plumbing Vent Through Wall & Studor AIV's #2
I installed air admittance valves on my house to avoid putting any holes in the metal roof. No problems.
One thing you should consider is that most roofers will use some kind of silicone roof boot + sealant to seal around any vent stacks on your roof. I don't know what the life expectancy is, but doubt it will last anywhere near the life of your standing seam.
I would strongly prefer putting the vent stack through the wall.
   / Running Plumbing Vent Through Wall & Studor AIV's #3
Air admittance valves seem to last a long time in my experience. I have 5000 sq feet of metal roof with zero penetrations.
Thanks for the input. I will of course make the AIV's accessible in the attic area with an access panel.
Code prevents from using 100% AIV's as it requires at least one open air vent to the outside but I will do the wall penetration. The only issue is that my wall is ICF so there is 6" of reinforced concrete that I will have to do a core drill. Not ideal but will have to find a way to core drill a 4" hole into the concrete wall.
   / Running Plumbing Vent Through Wall & Studor AIV's #5
Rent a core drill and bit. A decent rental company will have them.
Your plumber should know about core drills. Probably not the firt time they have had to drill concrete.
   / Running Plumbing Vent Through Wall & Studor AIV's #6
Many of the larger concrete drills (esp. rentals) come with or have available a stand that will hold the core drill horizontal. I would just have a plan for how it is going to be fastened to the floor or wall, and what you are going to do with the wet slurry.
If it is at all possible, I would try to avoid cutting rebar. Not that the drill couldn't do it, it just cuts into your wall strength.
All the best,
Peter
   / Running Plumbing Vent Through Wall & Studor AIV's #7
When I built my hunting camp over near the coast I put a metal roof on it and like you didn't want vent stack holes in my tin roof, I went with studor vents in the attic and have no had any problems in 5 years, did the same in my barn bathroom 18 years ago and have never had a problem with it either.
I asked the question in another post but with a metal roof. Should I ground out the roof to prevent damage in case of a lightning storm?
2001 Rinker Captiva 232 (A50121)
2001 Rinker...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
Loegering Metal Skidloader Tracks (A50774)
Loegering Metal...
Stanley MB3570 Skidloader Breaker (A50774)
Stanley MB3570...
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
Agri Metal Tuff Vac 5000 (A50774)
Agri Metal Tuff...
