Running on one Cylinder
   / Running on one Cylinder #21
gotta love the welders dance :eek: hired a "certified welder" turned him loose on a overhead welding project with arc welder, a berry the size of a gumball dropped down his shirt and proceeded to the belt line where it continued its journey down to his sock, wow!!!!! what a incident/safety report that was to write up, all in all everything healed ok:cool:
Well, I had more running on one cylinder today. This time I had no spark on the cylinder that was not firing. I replaced the coil with an earlier version coil that I had, heated the plug with a torch to burn off the gasoline and let it run. It did take a couple of minutes to start running on both cylinders, but it ran fine while I mowed. So my guess for the initial problem on this thread is that the coil was intermittent and finally failed completely. I also had some problems last Friday, but it cleared up after awhile. Hopefully I have the solution now. I will order a couple of coils tomorrow to keep as spares. Any comments would be appreciated.
   / Running on one Cylinder #23
I wonder if you have a hair line crack or a stress crack in the coil had a ford that would lose spark due to a internal crack it would stop throwing a spark a very frustating intermittent problem, my 425 loads the plugs and runs on one cylinder if I let it idle for more than ten minutes the motor has 160 hours and a second set of plugs, problem not as bad since muffler has been replaced
Possibly that. At least it's not intermittent any more. Those are the worse kind of problem.
Had a no cold start problem today. I figured it might be the fuel solenoid even though it clicked when I turned the key on. I pulled the air cleaner and it was very dirty on the outside of the carburetor. I started to clean the area and suddenly heard a click and saw the choke close. Evidently it was stuck open. I tried starting the engine and it fired right up. I then cleaned the rest of the carburetor outside, and then pulled the fuel solenoid and cleaned it. The engine ran fine all day with several hours of gravel hauling. I did have one engine cutoff. When I checked the fuel filter it had some air in it. I held it vertical and the filter filled with gasoline. It ran fine after that. This sounds like vapor lock. The gas tank was down to about 2 inches of fuel. Any comments on this. Lots of little problems lately, but they don't seem to stop me long. I have 827 hours on the engine, and have never cleaned the outside of the carb.
   / Running on one Cylinder #26
Not sure BobRip,
But I think there is something to letting the fuel get down to low. Seems like mind does funny things to when I let the fuel tank get to low.
Not sure BobRip,
I agree. Especially if the engine is hot. It stands to reason that vapor lock is not as likely to happen if there is more pressure at the filter and pump inlet.
I had another choke failure to close this morning. I forced it closed and did my work. Then I removed the choke plate by taking out the 2 Philips head screws. I then pulled out the choke shaft and cleaned it and the holes it goes in. It seem to work smoother after reassembly. We will see how is goes tomorrow.
OK, the choke worked fine this morning. Cleaning the choke shaft and the holes it runs through while disassembled worked.
   / Running on one Cylinder #29
"Cleaning.....worked."
Yes! BobRip, always nice when the labor applied is not for nought, congrats.
Well had another problem yesterday. When the fuel is low it would die after a few minutes of running. I had replaced the fuel pump recently and did not think that could be it. I checked for blockage in the lines, tank outlet, and filter and eventually put the old fuel pump back in. Now it's working OK. I ordered a new fuel pump today. I hope this is it. I really did not know how to test this pump, but when I blew air into the outlet with my mouth air came out the inlet. It sound like the check valves are bad.
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2013 Godwin CD103M Towable Diesel Pump (A59228)
2013 Godwin CD103M...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
Deere 310L (A53317)
Deere 310L (A53317)
2020 Utility FS2CDHE 45ft. 35 Ton T/A Drop Deck Flatbed Trailer (A60460)
2020 Utility...
