Oil & Fuel Running issue on 63 Case 441 gas
   / Running issue on 63 Case 441 gas #1
SharkmanDan
Sequoyah County, Oklahoma
Kubota B7100D
I have a 1963 Case 441 gas tractor. A few months ago, it was running good, I took it to a friend's and helped him mow with it. I left it at his place, then went back, recently and picked it up. I had a trusted friend get it, as I had just had hip replacement surgery. It ran great, loading it on, and unloading it from, the trailer. Parked it for a few more weeks, as there wasn't much work needed to be done with it. We did not notice that the air cleaner had fallen off of the M-S carb.
Yesterday, we started it, and it idled fin for a little while, then died. We checked the fuel, and it seemed to have run out. We refilled the tank, and started it back up. It would then only start with full choke, and when the choke is opened, would die. It seemed to be flooding easily. So, we took the carb apart, cleaned it, and got some dirt, but not much from it.
Put it back together, started well. Open the choke, and it DIES. Sucking air, real hard, into the carb, with the new air cleaner.
It idles well with the choke fully closed, but as soon as we try to throttle up, or open the choke, it sucks air very hard, and dies, refusing to idle.
I have some mechanical knowledge, but I'm no mechanic. It's a simple system, with that carb. And ran great, just a few weeks ago. But, the weather was much warmer then.
What am I missing?
   / Running issue on 63 Case 441 gas #2
It sounds like a lack of fuel. You may have a blocked fuel line or a clogged fuel filter. Take the line loose from the fuel tank and make sure fuel can flow out freely then continue down the line from there.
We are getting a pretty decent flow of fuel out of the filter, to the bowl, but not like it would be, if we just ran it out of the bottom of the tank.
You may be right. My hand who knows more than me, about mechanics, but still is no mechanic, is working on it right now, and it is sounding much better. I'm hearing it go up and down in RPM's and idling smoothly, in between accelerations.
I'll let you know his final verdict.
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
23018 (A55758)
23018 (A55758)
2020 CATERPILLAR 323 EXCAVATOR (A52709)
2020 CATERPILLAR...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A58018)
2017 VOLVO VNL...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
