Running a Shorter Bar Stihl MS 251
   / Running a Shorter Bar Stihl MS 251 #1
FoldedFrog
DC130
I’d like to clear up a little confusion for myself. I just bought a Stihl MS 251 chainsaw which comes with an 18” bar. The manual lists Rollomatic E guide bars from 12” to 18”. However, when I go to the Stihl website they only list an 18” as “recommended “. I know most people ask if they can run a longer bar but I want to do some carving and a shorter bar would help with more if the delicate work. Are there any problems, that I’m not aware of, with using down to a 12” on the 251?
Thanks in advance.
   / Running a Shorter Bar Stihl MS 251 #4
The saw will feel balanced with one particular bar length, and becomes less comfortable when you go too long or too short. That's the main impact I have noticed. Sometimes you can counteract that with heavy/light bars.
   / Running a Shorter Bar Stihl MS 251 #5
My go-to saws for general woodcutting have been 50cc with 16" bars. As you noted the standard is 18", but I have used 16" for so long that is the balance I am used to. Twelve inches would probably feel short with that powerhead. On my top-handled 192 I went from stock 14" to 12"; the older I get, the better it feels.
Yes. I had read about balance. Since I’m planning to only use this for carving mostly with the tip, I’m hoping it won’t be too much of an issue. For the same reason, I was thinking that a shorter bar wouldn’t tend to kick back as severely when using the tip to create finer detail. Thanks for pointing that out.
Good point. I’m old enough it should feel very good!
   / Running a Shorter Bar Stihl MS 251 #9
   / Running a Shorter Bar Stihl MS 251 #10
Kickback on saws is from the upper and lower corners of the bar end. A lower degree on the end of the bar lowers the kickback. Depending on bars some have a more square outer end verses a more pointed end with more rounded corners.
2019 Chevrolet Tahoe SSV 4WD SUV (A50324)
2019 Chevrolet...
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
2012 International 4300 Reefer Truck (A52128)
2012 International...
Wolverine Skid Steer Drum Mulcher (A50515)
Wolverine Skid...
2014 Chevrolet Express Cargo Van (A50323)
2014 Chevrolet...
UNUSED AGT MY50R EXCAVATOR (A51243)
UNUSED AGT MY50R...
