Running a Hydraulic Motor - Valve Question
   / Running a Hydraulic Motor - Valve Question #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I used a hydraulic motor for the first time this weekend. I have a John Deere 5525 and a Grassworks Weed Wiper. I had to rig a bungee cord to hold the lever in the proper position to run the motor. Is there any difference between that bungee cord I have and having to pay $1500+ for the deluxe valves with the selectable motor option? I know that on the deluxe version valve 1 has a flow regulator. The weed wiper has one, so no biggie.
I can live with the bungee cord - I just want to make sure I am not hurting anything. Next time, I am getting the deluxe valves. I didn't know they existed when I bought my 5525.
Thanks,
D.
   / Running a Hydraulic Motor - Valve Question #2
No direct knowledge of the JD valves, but in general...
When running a hydraulic motor, you have to remember that it is really a pump in disguise. So, if there is a lot of rotational momentum (like a rough cut mower), the motor will keep turning from that momentum. You stop the flow of fluid to the motor it can't instantly stop. It will then start acting like a pump, but the lines will be deadheaded with no relief. If the momentum can provide enough instant engery, the pressure can get very high very fast and "bad things" may happen.
Motor spool valves allow for free wheeling in neutral. Standard spool valves don't. At a guess, the "deluxe" valves may have a relief built in? You may want to add a relief valve between the inlet and outlet of the motor for protection.
Fairly cheap and easy to do. Parts from surpluscenter.com.
jb
   / Running a Hydraulic Motor - Valve Question #3
jb is right about the motor valve. Another way is use a cushion valve at the motor, then you can get away with a regular valve. A cushion valve is nothing more than 2 relief valves in 1 housing so the motor can be protected when turning ether direction. Be nice to have detents instead of the bungee.
DRL
Surplus Center Item Detail
   / Running a Hydraulic Motor - Valve Question #4
Yep.. detents. and the freewheel.. though, if the motor has an ORC installed.. it won't be an issue. One thing good about htedetents.. is if a stoppage is encountered.. most valves with detents will auto - center.. etc. With the bunji.. you may / will be running against relief.. etc.
soundguy
   / Running a Hydraulic Motor - Valve Question #5
The bungee will work just fine, save your money. Farmers used orbit motors for 25 years before anyone knew what a motor control valve was or put one on a tractor. The concern about shock loads when stopping are valid, but can be mitigated by using a zero pressure return (in the hydraulic fill tube on a 5520 not sure about a 25) rather than the existing SCV coupler for return oil. That solution should run about $100 unless the fitting is already in your fill tube, then it's less. Alternatively, use the "lower" postion of the SCV control to power the orbit motor and shift it to "float" to stop rather than neutral. Either solution is cheap and effective unless you require the motor to run both directions. Then a crossover relief is the best solution for your present setup. Detents set above relief (as in motor spools) are fine until you forget to reset them for common cylinder use; then they are a liability and can damage pumps if the valves do not return at the end of the cylinder's stroke.
   / Running a Hydraulic Motor - Valve Question #6
I like the float idea.. whoever I'm assuming not everybody has a float setting that opens both ports... My deluxe remotes on my NH do.. but my older ford remotes.. detent or not don't. I'm sure there is variance all over the board between remote setup... however.. if the motor is 1-way.. and ORC coupled int he driveline will make all that no problem..
soundugy
   / Running a Hydraulic Motor - Valve Question #7
The zero pressure return for applications requiring only one direction of rotation is actually more foolproof. Instantly stopping flow on the pressure side is of no consequence; the problems start when the return is suddenly closed.
   / Running a Hydraulic Motor - Valve Question #8
Sounds like it would be akin to deadheading a pump if the motor had a heavy inertial load and NO ORC protection. if the return was blocked suddenly.. ( and no relief on the output was present).
Soundguy
   / Running a Hydraulic Motor - Valve Question #9
Soundguy
I'm not picking on you, Chris, really. I just can't develop any enthusiasm for your mechanical answer to a hydraulic concern. It is just one more frigging thing to have to design into an implement or whatever that someone else has presumably done at least a fair job of engineering. The vast majority of off-the-shelf hydraulic motors in applications germain to this discussion would have round, keyed shafts of one inch diameter or possibly a little more. Never have I seen one with a 1-1/8" or 1-3/8 " six splined output shaft. So we get to adapt a round keyed shaft on the motor to a splined shaft to accept our ORC that just cost us $45-$60. Then we get to adapt the ORC's output BACK to the round, keyed drive coupler the implement had to accept the motor to begin with. Go find one or two orbit motor applications and check out what would be required. Makes a zero pressure return or crossover relief look pretty inviting IMHO. BTW, you are missing out on the 9 inches of snow I just had to blow out of my drive up here.
   / Running a Hydraulic Motor - Valve Question #10
You could just put a check valve between the IN and OUT lines to the motor and do the same as an ORC.
DRL
UNUSED EINGP SCL850 STAND ON SKID STEER (A54756)
UNUSED EINGP...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
NIFTY SP64D 4X4 MK2 TELESCOPIC/SCISSOR MAN LIFT (A52705)
NIFTY SP64D 4X4...
