runaway or not on ck30
   / runaway or not on ck30 #11
You guys make me nervous. My CK30 is old, a 2005 model, and with 918 hours the engine and injection pump has always worked perfectly. Every tank is off road diesel with Diesel-Kleen.
   / runaway or not on ck30 #12
Sounds more positive. the first person you talked to must never have been around a diesel very much.
maybee their floor sweeper / telephone answerer person????
soundguy
   / runaway or not on ck30 #13
I think there are a lot more tractors that haven't had the problem than those that have. But, I'd sure keep it well lubricated and try to minimize a lot of throttle variations (as with the foot pedal). Michigan iron said that the manual trannies were more prone to the failure due to this. But, I suspect all that have the brittle gear can fail.
You're OK until it fails..... isn't that an obvious one!:D
   / runaway or not on ck30 #14
My CK30hst is a 2004 model with around 350 hours and it works perfectly. I use Stanadyne brand additive with on road fuel. I hope my pump holds out because I'm not looking forward to buying a new pump either.
   / runaway or not on ck30 #15
Is there a part in the pump that can be proactively replaced?
   / runaway or not on ck30 #16
Someone here mentioned getting the pump rebuilt instead buying a new one if out of warranty. So I guess the parts are available but don't know where to get them. Kioti seems to just sell the pump as a unit.
   / runaway or not on ck30 #17
perhaps call / take the pump numbers to a diesel shop and ask ....
soundguy
   / runaway or not on ck30 #18
Michigan Iron indicated in an earlier thread that there were "pump shops" that could rebuild it for much less than replacing it.
   / runaway or not on ck30 #19
Does anyone know the models, years, etc. that are prone to this injector pump problem? I have a 2005 CK20 gear with nearly 400 hours and no problem so far.
Just an update from me. Kioti took care of this. Could not complain of anything about the process. Thanks to Dave from the GO KIOTI team. Small paperwork issue in the beginning but Kioti worked it out. Dealer said it runs fine and I can pick it up next week. I cannot get back over there till then due to my schedule.
bad boy zero turn 72 (A56859)
bad boy zero turn...
1712 (A58375)
1712 (A58375)
Adams 5T Pull-Type Fertilizer Spreader (A56436)
Adams 5T Pull-Type...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
2013 KENWORTH W900 TRIAXLE (A58214)
2013 KENWORTH W900...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
