Run your car on fryer grease
   / Run your car on fryer grease #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
www.frybrid.com
Thought this may interest the inquisitive.
Maybe they'll make a Kioti kit?? /forums/images/graemlins/shocked.gif
   / Run your car on fryer grease #2
I can see it now, "I'd like an eggroll, fried won ton and fill er up." /forums/images/graemlins/grin.gif
   / Run your car on fryer grease #3
My brother-in-law recently told me about a guy he does business with that runs an F-250 on 25% diesel / 75% KFC grease.
The guy is a mechanical engineer. He supposedly made a grease filtration system in his garage for about $500.
He gets the grease free! That's cheap fuel.
Why hasn't Exxon told us about this? /forums/images/graemlins/confused.gif
   / Run your car on fryer grease #4
Helped a friend and his daughter install one of the Greasecar kits in an old VW Jetta. You warm the engine up on diesel and switch to grease. Before shutting down, you throw a purge switch to clear the fuel lines and switch back to diesel.
You plumb the heater hoses to the trunk where the 2nd tank is located. Coolant is run through the tank (and around a second filter) and the fuel line is run inside on coolant line to heat things up. Would take some engineering to install on a tractor /forums/images/graemlins/wink.gif.
   / Run your car on fryer grease #6
This concept has been around for years. ( Greasel )
The reason for heating the oil is to get it to flow and burn easier. If some smart chemist out there would come up with an additive to add to straight vegetable oil to get it to flow at low temps, that would be the end of the oil (and ag income) problem.
Im afraid if the oil companies control this I wont be able to afford french fries anymore?? /forums/images/graemlins/grin.gif
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
48 Inch Grapple Root Bucket (A55218)
48 Inch Grapple...
