Run off ditch
/ Run off ditch #1
Anonymous Poster
Epic Contributor
I need to dig a run off ditch through my property. It is to catch rain water coming down the hill and re-direct it to the pond. I have four options as ways to do this. I have a middle buster, a box blade, a scrape blade, and a bottom plow. Of these 4 , the middle buster is the easiest (to me anyway) , but I am concerned if it is the best? The ditch doesn't have to be deep, (5-8 inches or so) so I know the middle buster will work. But I "think" the scrape blade will work just as good if not better.
Any recommendations????
Thanks,
greg
/ Run off ditch #2
How wide does the ditch need to be? Is it going to be a "swale"? Just speculatin', but I'd probably make a couple of passes with that middle buster to break up the ground, then use the box blade to remove and spread the dirt; i.e., clean up the ditch.
/ Run off ditch #3
I did a similar project last week and I used my back blade. I tilted it as far as it would go and got a nice 6 inch trench. Once I finished I leveled the blade and put it at an angle to move the extra dirt farther away from the ditch.
/ Run off ditch #4
Greg,
I think that if you have a box blade, that would be the implement of choice for this project. If it has scarifiers, I think you might just be able to tilt your box blade to one side (by adjusting your side link), and make a nice gradual ditch by going over the ground a few times each way.
/ Run off ditch
Thanks. Not necessarily a "swale" (as I understand them anyway), but just to catch the water coming down the hill and move it towards the pond. Should only be an issue during really hard rains. Won't be a lot of "soil" as it is in a grassy pasture. I don't think it has to be very wide either. I like the idea of the scrape blade and I may try it.
Thanks for the ideas,
greg
/ Run off ditch #6
bottom plow did it for me, I needed the exact same on my sledding/hunting/target backstop hill.
/ Run off ditch #7
Greg -
My very first tractor project was to clean up some drainage ditches and install some culverts, and I naturally took pictures of the whole thing. /w3tcompact/icons/grin.gif
Where the ditch had disappeared altogether, I with rippers down and just scraped away. I then came back and cleaned up parts of it by <A target="_blank" HREF=http://www.acknowledge.com/tractor/L2500DT/photos/DitchDigging.jpg>attacking from the side with my FEL.
Like I said, it was my first time doing anything useful with the tractor, but <A target="_blank" HREF=http://www.acknowledge.com/tractor/L2500DT/photos/culvert1a.jpg>the final results</A> were just what I was going for.
/ Run off ditch #8
I ditto what Bird said. The middle buster will loosen everything up and make the spoils it easier to remove but if you have a scraper blade that tilts and angles you can use that to drive straight and windrow the excavated dirt without worrying about dumping the spoils (as you have to do periodically when using a boxblade.)
/ Run off ditch
You already have heard some good ideas. Here is an idea onlyyou can decide if it is good or not. If you own a heavy rear blade that will angle and tilt you have it made. I would angle the right side of the blade forward one position. I would then tilt the right side one position down; if it is a Landpride or Bushhog. You can then with a little practice make a ditch in no time. You can then adjust the blade and slope the sides or do whatever you want. Just catch your ground in the proper moisture condition where it works the best.
Just a thought
Greg H
/ Run off ditch #10
Harv,
This community would be nothin' without pictures.
At least for unimaginative folks like me.
Buck
/ Run off ditch #11
A narrow ditch is fine, until the sides collapse or it needs cleaning. I had a similar problem, and constructed a 5' swale by digging a trench with the middle buster, and then dropping one set of wheels (one side of tractor) into the trench, putting my tractor in FWD, locking the rear differential (straight trench), and carving out both sides of the swale (one side on first pass, turn tractor around, and then the other side). An angled box blade will certainly do the same thing, albeit with more passes. Not sure about the scrape blade - depends on how dense / heavy the soil is, rocks, etc. Anyhow, I planted grass in the swale, and can mow it easily. The aforementioned was not my idea - someone else on the forum - without which I'd probably mess up most projects I attempt.
/ Run off ditch #12
i think i would opt for the middle buster, then use the box blade or scrape blade to finish it. if u need to mow this area and u want a nice look, u can dig your ditch fill it with good drainage stone, then cover it with a few in. of dirt. it will move the water and give u a nice finish look.
/ Run off ditch #14
Now... what do you think I can use... /w3tcompact/icons/smile.gif
Let's try this again.../w3tcompact/icons/wink.gif
/ Run off ditch #15
Now will the real ditching implement please stand up... /w3tcompact/icons/smile.gif
(see attachment)
/ Run off ditch #16
You can also use this implement... but most don't normally "tilt" this much... /w3tcompact/icons/eyes.gif
(see attachment)
I can't find my other picture... but this actually goes a full 360... so pick a number... any number... /w3tcompact/icons/blush.gif
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
58in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
58in Hydraulic...
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
3pt 6 Row Cultivator (A64119)
3pt 6 Row...
