Oil & Fuel Run issue with case international 254 3 cylinder Mitsubishi engine
   / Run issue with case international 254 3 cylinder Mitsubishi engine #1
RYANSRYDZ
Sparta, Tn
Case international 254
New to the forum and thankful for any help I can get, I have a early 80s 4x4 254 case international with the 3 cnl Mitsubishi Diesel engine . I have had a increasing problem with the engine where it begins smoking heavy and knocking a bit under heavy load, not sure if I have oil, water or hydraulic fluid entering the fuel system?? At first it's was only under a very heavy load using the loader and binding the power train pushing brush. Not very familiar with the systems or how or if they hyd system or oil system could be dumping into the fuel system, I guess I lean more toward the hyd system since it's high pressure and I don't seem to be loosing the coolant I would associate with a blown head gasket. Any body who has see. This feel free to point me in a direction to get my little tractor back doing big work!!
   / Run issue with case international 254 3 cylinder Mitsubishi engine #2
Welcome from Wisconsin
Sure hoping some one has some idea where to start looking, it seems to be a great little tractor, but it's burning something besides fuel.
   / Run issue with case international 254 3 cylinder Mitsubishi engine #4
What color is the smoke?
White/grey
   / Run issue with case international 254 3 cylinder Mitsubishi engine #6
That kinda sounds like you have water in the fuel. At this point without having the tractor in front of me I would recommend that you change the fuel filter and drain the fuel tank then refill it with good clean fuel.
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2013 GMC Silverado 3500HD Flat bed (A55973)
2013 GMC Silverado...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Dewalt D28493 7/9" Angle Grinder/Sander (A59076)
Dewalt D28493 7/9"...
