Rubber Track replacement
   / Rubber Track replacement #1
polloloco911
John Deere 27D
Just bought a new track for my JD 27D (2009)
just don't know how to replace it.
Any info can help.
A mechanic talks about the grease valve in the side.
But not to sure.
   / Rubber Track replacement #2
I wonder if the grease valve he was talking about is the way they use to keep the tracks tight as they wear? If so it would make sense to relieve the pressure to replace the tracks.
   / Rubber Track replacement #3
Absolutely, correct. Remove the grease fitting from the tensioner. Collapse the tensioner piston and wrestle the track off. It is easier if you can get your machine 8-10 inches off of the ground. Good luck.
2017 Chevrolet Silverado 3500 HD Crew Cab KUV Enclosed Service Truck (A52377)
2017 Chevrolet...
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
2023 ACE SC804050L SANDBOX TRAILER (A54607)
2023 ACE SC804050L...
