Rear Blade Rubber edge for rear blade
   / Rubber edge for rear blade #1
Badger_Bandman
Genoa City, WI
I am looking for a bolt on rubber edge for my rear blade. I just resurfaced the black top drive and I would like to spare the surface; also, when the blade catches a crack just right it can really make a big bang!
Anyone have one on their snow blade or rear blade? Do you like it? What do you think?
Frank
   / Rubber edge for rear blade #2
Frank,
I do not have a rubber edge for my back blade. But I have plowed parking lots with a truck that had one. For light snow it was fine. When the snow was wet and heavy, it stunk. It would usually not scrape the now down to the black top in all areas. Then when it would freeze, the lot was a mess. I think that you would be better off installing a set of shoes on the plow. This also will not clear down to the black top, but it will leave the entire surface smooth(saving black top). That is at least my experiance with the bubber cutting edge on a plow, Take it for what it is worth. Good luck.
Dan
   / Rubber edge for rear blade #4
Ditto on the horse mats.. get the 3/4" thick ones.. they are sure tuff. One mat contains enough material for many years worth of blade edges..
soundguy
   / Rubber edge for rear blade #5
how does one cut a horse mat?
   / Rubber edge for rear blade #6
Hack saw works good.. or many passes with a sharp razor knife. Sawsall with a metal cutting blade works good to.
Soundguy
   / Rubber edge for rear blade #7
RalphVa said:
Some have reported making edges out of "horse mats".
Ralph
OK. Dumb question time. I was getting ready to weld up a set of skids for my newest rear blade, but maybe the mat would be better.
But, how have others mounted it? My 6-foot blade has a removable cutting edge. Do you replace the cutting edge with the mat? Do you sandwich it between the cutting edge and the mould board so it sticks out an inch, or so? Do you use the cutting edge bolts to hold it in place on the front or back?
I was also wondering if implement belt might be better, especially if it is sandwiched between the mould board and cutting edge.
Thanks,
Knute
   / Rubber edge for rear blade #8
Here's a link to my post last year on using a horse mat. It didnt work out for me, I pulled it off and went back to the blade edge. I could never get the blade angle set right to keep the matt from bouncing like a rubber eraser. It also wasnt stiff enough to perform as it should. If you can find a stiffer matt it may work. Or even better, go with one of the poly (or similar material) soft edges members have posted about.
http://www.tractorbynet.com/forums/attachments/68319-back-blade-soft-edge.html
   / Rubber edge for rear blade #9
How much did you leave proud? The less sticking out, the stiffer it is.
Soundguy
   / Rubber edge for rear blade #10
does wood wear to quickly? (hardwood?)
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
2239 (A51244)
2239 (A51244)
Xtreme XR1045 (A50120)
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
1996 Fertilizer Tender Trailer (A50514)
1996 Fertilizer...
