RTV900 Power Steering just quit?
   / RTV900 Power Steering just quit? #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Hi
Anyone ever experience an RTV900 power steering just quit?
No oil puddles, Hydraulic pump still works, steering wheel just goes around in circles, no stops.
I can barely turn front wheels by hand, Right front wheel has a lot of play by hand turning right to left, etc, left side not so much.
Steering was wandering driving down a straight road for quite a while.
I hope it the cylinder, less to fix and may help the steeering wander.
Are their checks I can do to determine which is bad?
Thanks for any help/
Controller part #10
Kubota RTV900G General Purpose model 2004 - 2005 Parts Diagrams
Cylinder, part #80
As the Dump works, It is not the Pump
   / RTV900 Power Steering just quit? #2
A friend had that problem. He had water in his power steering fluid.
Will
Anyone have a service manual they could PM the troubleshoooting section?
Fairly certain it is one of two possible problems.
A,) The Earth's climate is going Flaky!
Saturday -17F , wind Chill about -35F.
Today, 47 F , 60 Mph wind gusts. Very foggy.
That is a 60 F difference in 48 hours.
I think the Kubota RTV900 Hydraulic resevior vent lets moisture in the oil, and the system may have froze up. Our equipment building is still about 30 F on the inside, and all the equipment is really sweating. That's not good, as the insides of the engine, etc, collect water.
B.) Steering cylinder went south, I think the controller and pump are ok.
Once it warms up, I'll have my answer snd i will post.
Hi
Controller part #10
Cylinder, part #80
As the Dump works, It is not the Pump?? Maybe it is??
Does anyone know if the RTV900 has a two section hydraulic pump, i.e. inboard feeds dump cylinder and outboard feeds the steering??
Thawed out
Water in the Hydraulic oil. Will flush it this weekend. Any Hints?
Thawed out
Seems All Fixed.
Asctually good that this happened as now we we forced to change fluids.
   / RTV900 Power Steering just quit? #9
My 2007 RTV 1100 has a two section engine driven pump some of the early ones drove off the transmission. They came up with a new trap type vent as the ones with the red cap were sucking water in to the tank.
David
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
CASE TV620B SKID STEER (A52709)
CASE TV620B SKID...
