RTV900 Hydraulic Dump line
   / RTV900 Hydraulic Dump line #1
riptides
Super Member
Northern Virginia
Kubota ZTR, RTV, MX6000
One of my lines to the dump cylinder sprung a leak.
How to replace? Is there a relief bleeder somewhere that I must drain?
I need to get the bed up to do it. I guess I will need to ensure it is properly supported while working on the line.
This is one of the original 2004 models. A G designation I think.
Thinks sure came a long way for them.
   / RTV900 Hydraulic Dump line #2
Get the bed up and locked in place. The pressure relief was done by the blown line. Take the hose off that needs replaced and take it to a hydraulic shop/ parts store/ equipment dealer and have them make up a new one. Reverse the process and check the oil level
Thanks for the tips. Sounds pretty easy....and I hope so.
Do you know how to relieve pressure on that cylinder?
   / RTV900 Hydraulic Dump line #4
I would say it’s relieved when the line broke. But when you get the bed up and secured, work the dump lever back and forth a few times. That’s all I can think of
   / RTV900 Hydraulic Dump line #5
my RTV900 has a support arm piece (about 6" long) that is stored at the frame under the bed with a lead wire and pin. if you have one, you unpin and place on cylinder so bed will not come down.
   / RTV900 Hydraulic Dump line #6
The fact that you can manually lift and lower the bed when not running indicates it doesn't hold pressure when the engine is shut off. As noted above, there is a bracket attached to the arm to keep the bed from falling once lifted. Take the old one to your local hydraulic shop and they will get you fixed up while you wait.
   / RTV900 Hydraulic Dump line #7
Place the control lever in the float position. This allows the cylinder to move freely. Then lift the bed by hand or with a mechanical lift of some type.
That works! Thanks Richard.
Duh....you would think after 16 years of ownership I would know this machine. But it is turn key and go for me.
   / RTV900 Hydraulic Dump line #9
Me too Riptides. Mine is virtually trouble free. Those are the machines that seem to get neglected the most.....
I've hauled many, many, many tons of materials on mine. Most dependable workhorse I own.
2001 Ford F150 (A50121)
2001 Ford F150...
Unused Delta Crash...
2024 Scag V Ride XL (A51573)
2024 Scag V Ride...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
