rtv1100 poor design of ac recirculate filter.
   / rtv1100 poor design of ac recirculate filter. #1
Hersheyfarm
NE ky
Changing my ac filters yesterday I notice the inside cab filter allows major dust intrusion into the system. Its not sealed and just sits in front of the recirculating opening. I don't use recirculate but its not a sealed filter and if the door doesn't shut all the way or the foam seal wears out it sucks dust from the floor. In my case it gets pretty dirty this time of year so plenty of dust available. I plan to permanently seat it off but I would like to clean my evaporator and ducts. anybody tackled this?
There is no problem with ac this is just an issue I just noticed. The main filter under the hood seals pretty good. There is dust inside the duct so I know its made it to the evaporator.
So I removed the actuator door and sealed the recirculating opening. It’s ignorant. The door does not seal at all when its closed and filter just sits in front op opening, no seal whatsoever. You can see the door in my pics but I vacuumed it before I took it apart. It was completely covered in dust. I removed the duct and sealed it off temporarily with cardboard and zip systems tape(good stuff). My hvac is now running solely from the filter under the hood that seals good. Flow seems a little lower as I suspect the great hvac of the rtv1100 relies on recirculating. If thats the case I intend on making a filter mount for recirculate opening.
45B994F2-0B0C-4047-B9D6-8327F7E44BE5.jpegDB31FD5A-7A86-4805-B52A-05B9143CBA15.jpeg30A6E824-110A-4F99-9980-A19F82E0248F.jpeg
   / rtv1100 poor design of ac recirculate filter. #3
Interesting.
Let us know yhour solution for a properly sealed filter for the recirculate function if you do so.
SDT
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
Honda ES 6500 Generator (A55973)
Honda ES 6500...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2019 Kubota RTV-X1140 4x4 Diesel Utility Cart (A56857)
2019 Kubota...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55315)
Adams Load Out...
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
