RTV X1140 stalling with 1/4 tank of fuel
   / RTV X1140 stalling with 1/4 tank of fuel #1
hayden
Veteran Member
VT
Kubota L5740 cab + FEL, KX121, KX080
This has happened to me a couple of times now. My 2020 X1140 will sputter and stall even though the fuel gauge says 1/4 tank. Any sort of incline will trigger it. So far I have always been able to get it restarted and running long enough to get home, but clearly there is a problem. I haven't dug in yet to figure out if it's a gauge problem and the tank is really empty, of it it's a pickup problem of some sort. The machine is low hours (70), fuel is clean, filter is recently changed at 50hr service. I have a filter on my storage tank pump, and never issues with any other machines from same fuel source.
I'm mostly curious if others have encountered anything similar, or if this is a one-off problem. Of course I'm out of warranty - Oh well.
   / RTV X1140 stalling with 1/4 tank of fuel #2
Sounds like either crud in the tank blocking fuel flow or.. an inaccurate gage. I look at fuel gages as approximate indicators not gospel and I much prefer a visual look or a stick to ascertain the actual level.
Next time it gets low I'll check with a flashlight to see if the level can be seen. It probably can, but I have only watched it visually when topping off. Off by 1/4 is a lot for a gauge. I don't consider that acceptable. If it was crud in the tank, I would expect the starvation to be more random, rather than correlated with 1/4 tank level or below.
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
2017 Claas Jaguar 860 Forage Harvester (A52128)
2017 Claas Jaguar...
David Bradley Manure Spreader (A50515)
David Bradley...
TRUCKING INFO (A50774)
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
Quick Attach Pallet Forks (A47384)
Quick Attach...
