RTV - X1100C
   / RTV - X1100C #201
Our newest Vehicle out of 15. Very high mileage (+10.3K & 2400 Hours) on this 2019 RTV-1100C @ +10.5Miles bought to augment our old RTV900. $17K. The 1100C definitely not seen farm use, as most golf carts have been worked harder. Now it will have to earn its keep.
  • PXL_20241204_182321428PXL_20241204_2019 RTV-1100C SN# 51512 (Mileage2).jpg
   / RTV - X1100C #202
Was it used as a security vehicle in it's previous life?
   / RTV - X1100C #203
You will love it !!
   / RTV - X1100C #204
That or facilities maintainence. Probably a security vehicle as bed was in such good shape. Added the LEDs and the bed rails and guards.
Bought at link below. Had it shipped to NH
Should have bought the low miles super clean 2023 repo they had at the time less the plow for $21k. This 2019 is in nice shape, but the miles scare me.
   / RTV - X1100C #205
That or facilities maintained. Probably a security vehicle as bed was in such good shape. Added the LEDs and the bed rails and guards.
That unit must have just pushed a little bit of snow once in a while and was never near any salt its whole life. Everything looks really clean, unless they used "rebuild in a rattle can".
Are the seats factory or have they been replaced? One would think as many hours are on that unit, the seats would show some wear.
   / RTV - X1100C #206
It was washed , detailed by the dealer, fluids change. The plow is new added by dealer. Interior is original, passenger door has been replaced. Plowed snow with it. The area we clear on the farm is at least an acre. If we have a foot of snow, it takes takes 4-5 hours using our 4 ton tractor with commercial plow.
We just had 5-6 inches and while stepson plowed with the tractor, I plowed for an hour with the 1100C clearing maybe 6000 Sq ft.
1100C plows ok with the 6' plow. For a normal large long driveway, the 1100C would be a great plow setup, especially with a 6-1/2' V plow like a Boss, etc.
The 1100C plows 3-4 times better than the big Polaris ATV we have and is about 1/2 as efficient as our.tweaked L39tlb. The 1100C can actually make a 6' tall snowbank.
Like all 1100C's, shifting foward to reverse kind of sucks. The glide shift power shuttle on tractor is easier.
   / RTV - X1100C #207
After a while you will develop a technique to ease shifting. You have to time it and/or blip the throttle.
But yes, that is the worst part of the RTV. I wish they would have made forward/reverse pedals in them like a tractor.
   / RTV - X1100C #208
What is the best Cable Rope for a UTV Winch?
The Synthetic Winch Rope snapped after a few hours of use on the Denali UTV Plow Blade Box with Box End Wings mounted to our new to us RTV-1100C. I repaired using an albright knot, and then secured the remainder of the black abrasion sleve to the rope with zip ties.
I am sure it will abrade and break again.
When it does I would like to replace with a larger better quality rope and abrasion sleeve material.
Suggestions welcome.
Thanks.
The plow wings make a big difference keeping more snow in front of the plow, turing the plow into a mini snow pusher.
These come two to a set. https://utvpartsandaccessories.com/...low-blade-box-ends-standard-series.html?gQT=2
I am thinking about putting a small set of wings on our tractor's plow also.
The 1100C has enough weight and ooph to push a decent size snow pile. 8-10" expected Saturday night.
Loving the heated cab!
   / RTV - X1100C #209
Our L39 plow have the end link of one of the hydraulic rams get ripped off. I also noticed the center pivot bolt is failing any the bolt hole elongated to 1"x 3"! Two of the 4 Cylinder pins are also bent. Plow is out for the count and more snow is coming. As we have about at least an acre to plow, the little 1100C has it work cut out for it. I will just plow out the 1/4 mile driveway, cars, and barn doors,/garage doors areas, not all the graveled areas
   / RTV - X1100C #210
Our L39 plow have the end link of one of the hydraulic rams get ripped off. I also noticed the center pivot bolt is failing any the bolt hole elongated to 1"x 3"! Two of the 4 Cylinder pins are also bent. Plow is out for the count and more snow is coming. As we have about at least an acre to plow, the little 1100cC has it work cut out for it. I will just plow out the drive cars, and barn,/garage area, not all the graveled areas
You'll do just fine. The heated cab on the 1100c sure does spoil you.
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
SUV (A59231)
SUV (A59231)
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
