RTV X1100C Will not start
   / RTV X1100C Will not start
Items to check:
Is there fuel in the tank?
Is there a blockage in the tank outlet?
Is the filter plugged or full of water?
Does the lift pump get the fuel to the injection pump?
Does the fuel stop solenoid operate so fuel gets to injectors?
If not, is power getting to the solenoid?
Note: any opening of the fuel system probably will mandate you to "bleed" the fuel lines and that should be in the manual as it is needed after changing the fuel filter.
Fuel in the tank. I only know that one so far. I will have to buy a manual. I bought it used and it was missing.
I have the fuel filter I can replace and it self bleeds when you install from a video I watched on it
part number Kubota 6A320-59930 for the filter then you need two O-rings they are 6A320-59940 and 6A320-59950
Items to check:
I want to say I am very thankful for your help. I have replaced the fuel filter today.
It was pretty dirty needed to be done. That did not fix my problem.
We then found the bleed valve and it is right after the fuel pump. When we opened it and cranked there was fuel the entire time.
Only thing left is the solenoid you were talking about. I will replace it asap and let you know how it goes.
Thank you again.
I only bought this 1 month ago and I have worked on it more than I have been able to drive it. I have put less than a half tank through it. It read 2700 miles and 450.6 hours. I didn't expect this from a Kubota.
   / RTV X1100C Will not start #13
They all need maintenance too so get it fixed while learning about the machine. The filter and solenoid at 450hrs is not that strange.
They all need maintenance too. Get it fixed while learning about the machine too. The filter and solenoid at 450hrs is not that strange.
Thanks Again
Items to check:
The fuel stop solenoid was the problem. I replaced it and started instantly. Thank you very much RUFFDOG I didn't know what to do without your help. Thank you again! Took two weeks for the part to arrive at my local Kubota.
   / RTV X1100C Will not start #16
Glad you are up and running! (y)
2016 Isuzu NPR-HD 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
2015 GMC Yukon XL SLT 4WD SUV (A50324)
2015 GMC Yukon XL...
(INOP) 2014 CATERPILLAR 279D SKID STEER (A51242)
(INOP) 2014...
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52128)
NEW Work Saver...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
