RTV tire air loss
   / RTV tire air loss #1
LGinIA
Iowa
JD X485 AWS,B2410,RTV900
Seems like I am always pumping up my RTV tires. They all seem to leak air and I am pumping up every 2-4 weeks. I would expect some air loss, but not this frequent and not all 4 tires. Should I install tubes or try to slime all the tires? Any other suggestions?
   / RTV tire air loss #2
I am not certain on this, but I thought the dealers were made aware of tire/rim compatability issues. They were to have reseated the tires after applying some gunk around the rim.
I am sure others will chime in shortly with more info.
-Mike Z. /forums/images/graemlins/grin.gif
   / RTV tire air loss #3
That's standard issue. /forums/images/graemlins/grin.gif Your dealer should be aware of the problem and put sealant in your tires for you.
   / RTV tire air loss #4
Call OTR at 1-800-833-6309
their have been some issues with tires leaking down!
OTR is the mfg. of the rtv tire and wheels.
they will make them good!
   / RTV tire air loss #5
</font><font color="blue" class="small">( Call OTR at 1-800-833-6309
they will make them good! )</font>
B2710,
So we all don't have to call, can you elaborate on "they will make them good"? Many of us have slimed our tires or otherwise addressed the issue so do I assume correctly that they won't be doing anything for us?
Brian
   / RTV tire air loss #6
Contact your dealer...they should know about this situation and fix it accordingly
   / RTV tire air loss
Discussed with dealer and he is contacting Kubota. I'll let you know the outcome.
Thanks
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
CASE IH 2020 - 30' GRAIN HEAD (A51247)
CASE IH 2020 - 30'...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
KISMILE HBZB-30N ELECTRIC ICE MAKER (A51248)
KISMILE HBZB-30N...
2011 John Deere 4520 Front Loader Utility Tractor (A51691)
2011 John Deere...
2014 Ford Escape (A50323)
2014 Ford Escape...
