RTV Temp Gauge:Problem?
   / RTV Temp Gauge:Problem? #1
Slippy
Veteran Member
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
I have read posts regarding diesel engines and the necessity that they run at a proper operating temperature. My gauge does not move at all. Should I be concerned about the engine not operating at a proper temp.? I have read a thread in this section about temp not moving, or even very little even in summer time. Can this be a good thing? It is really cold now and concerned that running unit will cause engine damage.
   / RTV Temp Gauge:Problem? #2
Here's an attachment from a previous post that gives the procedure to test the sender and gauge.
   / RTV Temp Gauge:Problem? #3
Mine did the same thing. Now, on the 1/2 mile trip to the mailbox, at 16 degrees it reads a 25% on the gauge coming back up the long grade. If it never moves, I think it is broke.
   / RTV Temp Gauge:Problem? #4
The only time mine ever moved was when I was pulling a trailer with about twenty people for a hay ride. Only then did it move very little.
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Toro Workman Utility Cart (A51694)
Toro Workman...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2006 Mastercraft S-05-1142 (A50120)
2006 Mastercraft...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
