RTV Stupid Human Trick
   / RTV Stupid Human Trick #1
ovrszd
Epic Contributor
Missouri
Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Time to change the oil. Pulled onto the drive-on hoist in the shop. Raised it up. Went underneath and drained oil, changed filter, greased rear axle joints, looked everything over real good, dropped the hoist. Time to fill the engine with oil........ Uh-oh,,,,,, forgot to raise the bed....... Hydraulic lift bed, can't start the engine to raise bed, engine located under front portion of bed...... :eek:
Fortunately the bed lift lever has a "float" position. Put the lever in float and lift/tilt the bed by hand. While lifted quickly snap the lever back into the neutral position which held the bed up.
Probably need to mentally focus on a better step by step procedure for oil changes. :D
   / RTV Stupid Human Trick #2
At least no one was harmed during this foray:thumbsup:
   / RTV Stupid Human Trick #3
There is this thing about painting floors with a brush and a bucket and painting yourself into a corner?:)
Glad you worked around it..:thumbsup:
   / RTV Stupid Human Trick #4
To quote Homer Simpson, "D'oh!"
You'll get it right next time!
   / RTV Stupid Human Trick #5
That's not stupid. Starting the engine up to raise the bed and add the engine oil, now that might be tilting toward stupid.
   / RTV Stupid Human Trick #6
Hey, as long as nobody else knows (and surely we won't tell), it never happened ;)
   / RTV Stupid Human Trick #7
If you ain't bleeding you done something wrong in my world.
   / RTV Stupid Human Trick #8
Well I expected the "oil on the floor, from forgetting the drain plug" story, so you done good. :thumbsup:
   / RTV Stupid Human Trick #9
On my RTV 900, you need the bed raised in order to put in the oil, but when servicing the hydraulic oil, you must not raise it too high or the bumper interferes with removal of the oil filter protection housing. Found that out at last oil change when it was hard to get the housing off and impossible to get it back on. Lowered the bed back down and it was easy as pie, bolts slid right into the mounting holes.
I'm with ya Murph.
I just totally blew this off. Last time I changed it, no problem. :)
2006 John Deere 120C Midi Excavator (A50322)
2006 John Deere...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50323)
2015 Eager Beaver...
2018 Dodge Grand Caravan SXT Van (A50324)
2018 Dodge Grand...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
Kubota L2650D Compact Tractor w/Loader (RUNS) (A50774)
Kubota L2650D...
New Holland B95 Backhoe (A50490)
New Holland B95...
