Rtv servo issues
   / Rtv servo issues #1
Steve rtv
Horsham uk
Rtv 900
After my wife harrowed the field I noticed that the rtv occasional would rev but not turn the wheels , this has gradually got worse with a load it will barely move .
Today it will not move at all engine revs fine all cables linkage etc seem fine , I have adjusted the servo adjustment screw the one with 14mm lock nut this makes absolutely no difference is now so bad it will not move at all , what is under this screw is there anything in there .
When I put in to low it feels as if it wants to reverse but doesn't .
Is there something in this transmission that can get stuck ?
Any help or pointers appreciated
Steve
   / Rtv servo issues #2
Sounds like you may have a burned out charge pump in the HST transmission. TIME for a dealer visit sounds like to me.
   / Rtv servo issues #3
Am I correct in assuming that the problem occurs in both 2WD and 4WD?
Steve
   / Rtv servo issues
Yes in both all it will do is move back about 1/2 inch then nothing , how much is a charge pump is it easy to get too ?
Steve
   / Rtv servo issues #5
What happens when you step on the differential lock? My RTV900 stopped pulling once but when I engaged the diff lock it took off. I found out the splines were worn out on the one side of the wheel hub & the axle was just turning inside the hub.
   / Rtv servo issues #6
That's why I asked the OP whether the RTV moved in 4WD. There's been at least one TBN thread about the spline issue on the rear drive.
Steve
   / Rtv servo issues
Steve
the diff makes no difference , if its the pump can i get to this or is it transmission out ?
steve
I am still suspect as it worked so well then nothing then fine then nothing as quick as that it seems to quick
   / Rtv servo issues #8
steve
How many hours?...
Has the HST been serviced and the correct fluid used?
Not sure I'd touch the servo adjustment at this point, but make sure that the rod and it's mount haven't worked loose or something strange like that. Unlikely, but gotta chase the obvious too.
   / Rtv servo issues #9
   / Rtv servo issues #10
Fluid level? Is it possible something got turned up in the field and poked a HST filter?
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
2014 Kia Sorento SUV (A50324)
2014 Kia Sorento...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
