Rtv servo issues
/ Rtv servo issues #1
Steve rtv
Horsham uk
Rtv 900
After my wife harrowed the field I noticed that the rtv occasional would rev but not turn the wheels , this has gradually got worse with a load it will barely move .
Today it will not move at all engine revs fine all cables linkage etc seem fine , I have adjusted the servo adjustment screw the one with 14mm lock nut this makes absolutely no difference is now so bad it will not move at all , what is under this screw is there anything in there .
When I put in to low it feels as if it wants to reverse but doesn't .
Is there something in this transmission that can get stuck ?
Any help or pointers appreciated
Steve
/ Rtv servo issues #2
Sounds like you may have a burned out charge pump in the HST transmission. TIME for a dealer visit sounds like to me.
/ Rtv servo issues
Yes in both all it will do is move back about 1/2 inch then nothing , how much is a charge pump is it easy to get too ?
Steve
/ Rtv servo issues #5
What happens when you step on the differential lock? My RTV900 stopped pulling once but when I engaged the diff lock it took off. I found out the splines were worn out on the one side of the wheel hub & the axle was just turning inside the hub.
/ Rtv servo issues #6
That's why I asked the OP whether the RTV moved in 4WD. There's been at least one TBN thread about the spline issue on the rear drive.
Steve
/ Rtv servo issues
Steve
the diff makes no difference , if its the pump can i get to this or is it transmission out ?
steve
I am still suspect as it worked so well then nothing then fine then nothing as quick as that it seems to quick
/ Rtv servo issues #8
steve
How many hours?...
Has the HST been serviced and the correct fluid used?
Not sure I'd touch the servo adjustment at this point, but make sure that the rod and it's mount haven't worked loose or something strange like that. Unlikely, but gotta chase the obvious too.
/ Rtv servo issues #9
/ Rtv servo issues #10
Fluid level? Is it possible something got turned up in the field and poked a HST filter?
/ Rtv servo issues
fluid is fine , filters in tact ,oil is super udt and is approx 125 hrs old , suppose i better phone the doctor !
steve
/ Rtv servo issues #12
Before you do, just check that the rear brakes are completely returning.
Others have reported brakes stuck on reducing speeds to 10-15mph.
The pivots get packed with mud, don't return properly and stay on.
With the rear jacked up, make sure you can turn each wheel by hand when the cam lever is all the way back. Possibly unhook cables and check for full movement on both sides.
Remove the debris and hopefully this helps.
Worth checking.
/ Rtv servo issues
def not the brakes ,
what is behind the servo adjustment bolt when i tighten it seems to bottom out frighted of going any more seems as if some thing is stuck or broke
/ Rtv servo issues #14
I forget the direction of adjustment as it's been a couple of years but too far one way and the machine won't move..Incrimentally the other way and the performance can be slightly adjusted to a point of diminishing returns.
Has anyone messed with that adjustment in the recent past?
/ Rtv servo issues #15
Here's my explaination of the servo adjustment for an RTV500 from a few years ago..Doubt it differs much for a 900 (ignore the RPM adjustment)..Can't be sure though:
You get to the screw by lifting the bed...There is a rectangular black bok that is just under the seat. If you look to the front of that, there is a stud sticking out, with a slot in the end. It is held in place by a 14mm jambnut. Loosen the jambnut and back out the stud one turn at a time. Make sure you re-tighten the jamb nut after each adjustment. Don't get carried away.
Remember that these are underpowered to begin with, so all we are trying to do is sqeeze everything we can out of it.
When you test drive, make sure you are at full operating temperature or you won't be able to tell if it helped or not.
After you get it where you want it, you may want to check the max RPMS as well. mine and many others were set to 3600...The update is to go to 4000.
/ Rtv servo issues
I am going to pressure test the hydraulics later to day to see if we have any charge pressure , This should prove if it is the charge pump, I have cleaned up and sprayed with lubricant the studs for removal so will see .
steve
/ Rtv servo issues
Well put gauges on the two ports adjacent to the HST filter both read 100 psi , There is a third port higher up but not accessible as behind a welded chassis part . We investigated under the top plate were the piston will slide back and forth adjacent to servo have proved that it will only drive in reverse piston only moves one direction so thinking seal in servo or on one end of the piston housing . this housing is filled with oil when engine is started so assume charge pump to be intact .
I would welcome any opinions .
Thank you Steve
/ Rtv servo issues #18
Steve,
Do you have a manual?
My knowledge of the servo screw, is this;
If you have adjusted it and now don't know were it is set at, then turn it in until it reaches bottom, back the screw out 1 1/2 turns. The range is 0 to 3 turns, with 1 1/2 being the middle. From this point you never go any further than 1/2 turn inward or outward from the middle position. In other words, from bottom it's 1-2 turns.
Should the plunger inside stick and not move out after adjusting to 1 1/2 turns, it may take a little drive to get the pressure up to move it out. Hopefully you can tell by lightly moving the screw out and back in by 1/4 turn to see if you can feel resistance. Either way leave it set a 1 1/2 turns. Otherwise you have to remove the servo body and free up the little plunger. Hard to see in the second diagram but the adjusting bolt pushes on that little plunger inside and it is positioned by the spring inside of it. You can just barely see a little gap between it and the servo body, that's the range of adjustment.
Adjusting on this screw has the least effect of all adjustments to the HST. So leave it until last and only move it by 1/8 of a turn either way to see if you get any improvements.
The neutral screw and HST rod adjustments are key to getting smoother shifting.
Anyone who has never adjusted there servo screw should make careful notes of it's factory position so they can return to that location if they make adjustments that don't work.
/ Rtv servo issues
No awaiting manual , we have been fiddling a bit today along the lines of the neutral adjustment as per your recommendations , and we now seem to have a machine that operates ,have not tried under load yet and it still does not answer why it would suddenly change from being great to awfull in one trip around the wood . We fiddled with it for a few hours and then it was if an air blockage or something that was stuck just came back . We got it going forward which was a great improvement from reverse only ! But it had no power then after changing gear and giving it some revs it just seemed to work .
I do understand the servo srew and the neutral adjuster now as I have had them apart . I will post more tomorrow when it comes back from my workshop at work and I get chance to test fully .
Thank you for you input gentlemen
Ta Steve
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2007 Ford F-450 Flatbed Truck, VIN # 1FDXF46P77EA72394 (A65563)
2007 Ford F-450...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
100 Gal Fuel Tank (A65643)
100 Gal Fuel Tank...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
Allmand 8KW Light Tower (A64194)
Allmand 8KW Light...
