rtv hydraulics?
/ rtv hydraulics? #1
334 lawn co.
alabama
john deere 5400 new holland ts 110
we have a kubota rtv 900 with the hydraulic package and nobody can give me an answer as to what the gpm on them is. does anybody know or think they know? we are looking for a sprayer that could attach via hydraulic connection.
/ rtv hydraulics? #2
If you have the model that has the axillary remote ( not the valve used to dump the bed) it has 5 gpm, 2000 psi.
The valve used to dump the bed can not be used to run hyd. powered tools.
/ rtv hydraulics? #3
Give 'em a call:
(310) 370-3370.
See if they can tell you or lead you in the right direction !!!!
/ rtv hydraulics? #4
If you got the plastic oil tank then just be careful that you oil tank does not get to hot. Else you will have a melt down.
/ rtv hydraulics? #5
kbotaman can you 'splain this further?
thx
/ rtv hydraulics? #6
The constant oil flow required to operate the hyd. powered tools causes the hyd. fluid to heat up, the standard models do not have the oil cooling systems necessary to keep the oil temperature from getting hot enough to damage the seals in the transmission as well as cause other trans. problems. As the trans oil heats up it tends to thin out lessening it's ability to provide proper lubrication to the trans.
The turf utility and the work site utility come with a a second valve that has it's own oil reservoir as well as a hyd. cooler and cooling fan to control the oil temp.
/ rtv hydraulics?
we got the attachment package. it has aux hydraulic connections on the back.
/ rtv hydraulics?
weve had it since '04. it was an early production model. not new.
/ rtv hydraulics? #9
Your unit does not have the oil cooler and larger oil tank. Your machine just has two hyd. outlets that shouldn't be used for continuous operation as stated previously. The hydraulic utility models with the large oill tank and oil cooler came out in 2005.
/ rtv hydraulics? #10
There is a conversion kit for your machine to upgrade It is still only 5 GPM though. Hope this helps.
2022 Timpte T/A Super Hopper Grain Trailer (A64194)
2022 Timpte T/A...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
2022 EZ-GO ELITE...
2025 48in. Farm Jack (A64553)
2025 48in. Farm...
