RTV glove box and underhood storage box
   / RTV glove box and underhood storage box #11
Whoa, nice box.
I havn't solved my under the (500) hood issues either. I have a fire extinguisher mounted, a military 1st aid kit and a tire repair kit "zip-tied" to the tubes. I am looking for a small 12v compressor to mount. My front $15hook is rated @ 4K pounds, the higher rated hooks were 40 bucks. I put my winch leads into a german mil gas mask bag, its in the cab on rainny days for now.
No way to see it but I cut a tiny "V" where the fire extinguisher rests
to keep it in place.
   / RTV glove box and underhood storage box #12
Well, I love this thread; I like to modify new or old equipment without compromizing the structural integrity.................
I got to brain-storming today and I come up with a tool box for under the hood of my 500. Basically, from the side it will look like one of those "do not disturb" placards that is placed on door knobs.
I put a lead pencil to the 1/2" cdx plywood tonight. I will butcher up the wood tomorrow and getter assembled.
The gyst of it is that it will hang on the horizontal 1 1/2" tube and rest on the fender wells.
The driver-side box is planned to be 8" wide, 6" high and 12" long (OD).
The passenger side has the glove box so it will only be 4" high.
I'll get er done and post some pics, would PM anyone that wants specifics. The box will easily hold the 12volt compressor I picked up today.
Maybe somebody can copy it and make millions.........;)
I like that idea. Is this sort of what you have in mind? My son made this in wood shop.The ends kind of look like what you described. Picture the wooden handle being replaced by the tube frame of the RTV and the box hanging off of it. Have to cut some slots in the ends for that. Screwed together, it would be able to hold a fair amount of weight. Put a hinged top on it to keep stuff from falling out; zip tie it down to prevent movement. Might go butcher up some wood myself, or put my son on it. He's already a better carpenter than me. :D
   / RTV glove box and underhood storage box #14
Well I finished the driver-side box. I was able to fit the compressor, a pint of slime, the winch hook and the 1st aid kit. I couldn't make the hooks on the top work so I cut them off, moved the box in position from below and secured the top with 5 screws. The holes for the 1 1/2" pipe were cut just shy so the top would fit tight.
Its "hangn in there"
   / RTV glove box and underhood storage box #15
Nice box, your son is a lot better wood-worker than me.
Lookin' Good!
   / RTV glove box and underhood storage box #17
I made one under the hood out of wood... There are two holes with threads which I used as a starting point & just built it using sheet rock screws... It worked great...sad thing is I just traded my 900 in for an 1140 so now I have to build another one...
   / RTV glove box and underhood storage box #18
Military surplus ammunition boxes are readily available at gun stores cheap; steel, waterproof, handles, strong latches, multiple sizes.
Olive drab color only.
I keep one in the bed filled with my chainsaw tools and spare cutting chains.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
2017 Ford F-550 4x4 Cab and Chassis Truck (A56858)
2017 Ford F-550...
CASE SR240B SKID STEER (A52709)
CASE SR240B SKID...
2025 LandHonor RB-14-66W 66in Rock Bucket Skid Steer Attachment (A56857)
2025 LandHonor...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A56858)
2012 Ford F-550...
2022 Big Tex 14LP Dump Trailer (A57148)
2022 Big Tex 14LP...
