RTV fuel gauge
/ RTV fuel gauge #1
avorancher
Deluz, CA
Kubota B7800, RTV900
Wondering if everyone's fuel gauge is like mine. Going uphill, it reads between 1/2 and full, downhill it reads between 1/2 and empty. I think I have around 1/2 tank (sitting in the garage before I start it).
Shouldn't it have some sort of buffer to slow down the movement? I can rock the vehicle by standing beside it and the gauge will move 1/4 tank up and down.
The good news is that I've only put fuel in it once so far.
/ RTV fuel gauge #2
I think all fuel gauges on these type vehicles(non electronic sending unit) all do the same thing.
Frank
/ RTV fuel gauge #3
I have over 8 hrs and my gauge still reads full. Have not gotten around to calling the dealership.
/ RTV fuel gauge #5
I have almost 40 hours on mine, and the gauge has never come down off the full mark.
I mentioned it to the dealer, and they will fix it when I take it in for the 50 hour service.
/ RTV fuel gauge
According to rubber and mcherry, the RTVs get better mileage than I thought. /forums/images/graemlins/grin.gif
At least my gauge moves, although a bit more than desired. I'm getting used to just checking it before backing out of the level garage.
/ RTV fuel gauge #7
I just replaced mine. Since it was delivered it always read 1/4 tank. Dealer ordered a new one and gave to me to replace. It took about 20 seconds. Unplug wires, pinch plastic wings on back of gauge, push out thru the back of dash. Reverse process to install new gauge. Easy, easy easy. New gauge reads proper fuel level but now fogs up. Contacted dealer, new one on order.
/ RTV fuel gauge
Sounds like they have a quality issue with the gauges. I did notice that once I get on the lower side of half tank, mine calms down and doesn't swing as wildly. That makes it more useful, since I'm mostly concerned when the tank is low.
I've never had any gauge fog up, including the speedometer that I just installed... not sure if I'm just lucky or it is weather related.
/ RTV fuel gauge #9
On the back of the gauge is marked the manufacturing date of the gauge. The original (non-working) gauge was made on 6/20/04. The new (working, but fogs up) gauge was made on 7/10/04. Also noted the new gauge gets pretty warm to the touch (from the back). Not sure if the old one did.
/ RTV fuel gauge #10
If it doesn't fog up within 1/2 hour with the temp gauge fogging at 1 hour; take it back to your dealership. Something is wrong then! /forums/images/graemlins/smirk.gif After 1 hour the only gauge that you should be able to read is the speedometer. Others should be a nice milky white. /forums/images/graemlins/grin.gif
/ RTV fuel gauge #11
Local dealer told me they're looking for a new manufacturer of the gauges due to all the quality and fogging issues and said they'll replace the fogging ones once they get the new ones in.
Based on what chief5 got, looks like they're still using the old mfgr.
For those of you with speedo's, does yours seem different than the rest of the gauges? Mine has a different font and back-light than the rest. I'm guessing it's made by someone else.
Dargo - I'd better return mine fast!! I only get fogging when it gets wet /forums/images/graemlins/confused.gif I get to watch my temp gauge do nothing and fuel gauge bounce from E to F (don't watch too long, it'll put you in a trance)
/ RTV fuel gauge #12
git my RTV arounf July this year and my gauge warms up and fogs too
Frank
</font><font color="blue" class="small">( On the back of the gauge is marked the manufacturing date of the gauge. The original (non-working) gauge was made on 6/20/04. The new (working, but fogs up) gauge was made on 7/10/04. Also noted the new gauge gets pretty warm to the touch (from the back). Not sure if the old one did. )</font>
/ RTV fuel gauge #13
LOL...good post Brent! /forums/images/graemlins/wink.gif
I'm pretty sure all these gauges get warm and they may be part of the reason they fog up. Anti-fog lens with these gauges should do the trick...I'm sure Kubota is working on this with their gauge vendor.
/ RTV fuel gauge #14
What a pleasant surprise today.
The service dealer showed up with new gauges! And they look
like they work!
My wife had called about them a while back. The diesel gauge actually works now.
Maybe if I can get some seat time in, I can get a report on the manufacture and model numbers.
-Mike Z. /forums/images/graemlins/grin.gif
/ RTV fuel gauge #15
Great to hear Mike,
Although mine aren't as bad as others, it's good to hear they're coming. Dargo won't know how to act looking at white needles instead of a pair of white eyes on his dash.
Dang... now that I think about it, I don't recall which of mine was bad. It only happens to mine when washing the machine. OK, did a search and believe it's the fuel gauge. Mike - do you have the speedo on yours? I now also remember the backlight on the speedo is different from the other 2. Wonder if the new gauges have the same backlight as the speedo this time.
/ RTV fuel gauge #16
Well, I went throught all the trouble of loading up my RTV and took it to my dealer last week to get my "new gauges". Complete waste of time! Not only do they still fog up, but now my fuel gauge does not even work!! I wasted 2 hours of my time to go backwards. /forums/images/graemlins/mad.gif
Yoohoo, Kubota people, any clue on when working gauges may be available for the RTV's??? I'm just really annoyed because I could not install them myself, and had to haul my RTV all the way across town and back just to get gauges that not only still fog up, but now do not work! Grrrrr!!!
I realize that there are first year bugs, but I've been trying to get gauges for literally months now. I took my RTV off of my property on a trip today for the first time and almost had to push it back to the trailer because the new foggy gauge does not read the fuel level properly. At least the last gauge worked when you could make it out! I like the RTV, but my patience and confidence in Kubota is starting to wane. /forums/images/graemlins/mad.gif
/ RTV fuel gauge #17
It is interesting how I've heard about 1st year bugs. I was told that the RTV was in production in Japan for several years before it came to the states so that it's been around but not in the states.?.?
/ RTV fuel gauge #18
It was never mass produced in Japan...some prototypes were made there. This is the first year of mass production of the RTV.
/ RTV fuel gauge #19
Does anyone know if there is one of those 'secret warrantys' on the gauges? My fuel gauge is completely dead but the machine is way out of warranty. Did anyone else get their gauge replaced by Kubota out of warranty? They are installing the driveshaft rattle fix for me next week.
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
2008 Ford Expedition SUV (A61574)
2008 Ford...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
159118 (A60430)
159118 (A60430)
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
