rtv 900 with 138 hours
   / rtv 900 with 138 hours #11
I understand about diesel engines needing to breath, I've got several. This is not a horse power issue, it is a matter of the horse power it has not going to the wheels. I would think I should almost be able to stall that engine if the wheels won't spin, and that is not the case.
Changing the hyd fluid may help, but they don't call for that before 100 hours. Are you all changing your fluid early to put in the other stuff?
It still acts like it does not build up enough pressure in the trans, I ought to be able to spin the wheels or bog the heck out of the engine if I can't spin the wheels, and I can't.
Wayne
I was one of the first RTV900 owners. I bought one within 2 weeks of them being released. Once I took off the 'worksite' tires and put some on with good traction, I would always run out of power before spinning in 4wd if traction conditions were good. There are several hills on my property that my Yamaha Rhino would fly up, spinning all the way, where the RTV900 would just stop and grunt on. I tried all the tricks of backing off the pedal etc., but I just flat ran out of power; period.
What did help tremendously was two things; one was changing the transmission filter and fluid (with Super UDT) at both 25 hours as well as again at 50 hours. The filters were partially clogged each time. The next change wasn't until 100 hours and the filter wasn't nearly as clogged. The second thing was to just, well, run the dickens out of the thing. The harder I ran it and the more hours I got on it, the easier it became to shift and the more power it seemed to have. It would never turn the tires in 4wd in good traction conditions, but it performed much better with 200 hours on it than it did with 25, 50 or even 100 hours. I didn't try it, but I'd assume your best option to have more power would to be installing a hand throttle so you can keep engine revs up all the way before you even touch the "go" pedal. I doubt it will be able to spin good tires in 4wd still, but it will perform better.
I am surprised that the RTV1100 I now have will turn the tires (exact same as I had on my 900; I kept them from the 900 and put them on the 1100) in 4wd and good traction conditions. It feels slower and more sluggish, but seems to have notably more torque. I'm hoping that it too will break in and perform better with a few hours. Good luck!
   / rtv 900 with 138 hours #12
Dargo:
Great information, thanks. I'll try changing the fluid as several folks have suggested, but it also interesting that you notice the same thing, where my mule 3010 would spin all three tires. Granted it was 500 pounds lighter and had less agressive tires, but the RTV just feels like the pressure relief valve is set too low or something. I'll try to track the dealer down and get their opinion. Like I keep saying, I ought to be able to stall the engine if it won't spin the tires, same as my HST tractor.
Wayne
   / rtv 900 with 138 hours #13
Wayne,
Do you have the hand throttle option? One problem I have with the RTV is the coupling of the hydro and throttle. I am going to bet that your hydro tractors do not couple the throttle to the hydro pedal. You crank up the throttle and ease up on the hydro pedal to get the most power out of a tractor (high RPM - low gear ratio). With the RTV a natural tendency is to give it more pedal. Well this gives it more fuel (good) but also puts it into a higher gear (bad). With the hand throttle you can control the throttle and gear ratio independently.
   / rtv 900 with 138 hours #14
Brian:
I don't have a hand throttle, and what you say makes sense, maybe I'll try it. And no, my tractors both have independant throttle and HST. But, it is also like the HST never gives out, in both I could stall the engine before the trans slips. Not that way on m RTV.
Thanks!
Wayne
   / rtv 900 with 138 hours #15
i now have the hand throttle to deal with this.
used to get "chocked" when starting out in a rocky patch. When the engine is revving high, and the pedal is pressed just a little there is a lot of torque at the wheels. the further you press the pedal the less torque is available.
Before the hand throttle I would stomp the pedal to get the rpm up then back off the pedal to get the torque to the wheels. Never liked doing that especially in tight quarters, as the "coast feature" would keep you moving long after your foot was off the pedal.
how do you add a hand throttle on the RTV 900? is this a kit form Kubota? or home brewed?:D
   / rtv 900 with 138 hours #18
The hand throttle kit is very helpful in situations where you need to control the engine spped separately from forward/reverse. Mine works well, although I don't always use it for flat and level, more for the up and down country.
finally completed... all the filters got changed, new trans fluid, cleaned exhaust and removed spark arrester (which was really plugged up). Performance is back :D BTW...the trans oil was really dirty looking. Learned more peddle does not mean power to the ground...backing off put the hydro into a lower ratio. Thanks for all the advice!
2007 Honda Odyssey (A56859)
2007 Honda Odyssey...
1994 SUNDOWNER 4 HORSE GOOSENECK TRAILER (A52708)
1994 SUNDOWNER 4...
2018 Komatsu GD655-6 Motor Grader, S/N 60403, PIN# KMTGD032PJA060403, Turbo Diesel Engine, 14' (A59076)
2018 Komatsu...
20357 (A55758)
20357 (A55758)
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
Utility Tilt Trailer (A55787)
Utility Tilt...
