RTV 900 Glow plug light
   / RTV 900 Glow plug light #1
mach158
Marion, IA
2007 Kubota RTV 900
I have a 2007 RTV 900 and the glow plug light does not light up when the glow plugs are used. The bulb appears fine. I tested the glow plug rail and it is getting 12 volts to the glow plugs so they are working. I do not have access to a wiring diagram and don't feel like paying $100 just to figure out why a bulb isn't lighting up. Curious if anyone could provide some assistance on the wiring routing for where the bulb power comes from otherwise I'll trace it in the spring time.
Thanks in advance for the help.
   / RTV 900 Glow plug light #2
Here's a pic of the wiring diagram for my 2008 RTV900 from the WSM. Sorry if it's not readable.
My light stays on as long as I hold the key in the proper position. But I think after a few seconds, when I hear a relay let go, the glow plugs have completed their mission. I just listen for that "click".
Thanks for the wiring diagram ovrszd!
Just went out to utilize your wiring diagram and checked the bulb and it worked. Not sure what changed. The driveway got bladed today is the only time it has moved since the light wasn't working. Must be a bad connection somewhere I guess. Guess i'll look deeper if it happens again.
UNUSED RAYTREE RMH680 HYD HAMMER (A51248)
UNUSED RAYTREE...
2023 UNVERFERTH 432 LOT IDENTIFIER 32 (A53084)
2023 UNVERFERTH...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
(APPROX 15) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 15) 2" X...
