RTV 900 Diesel Question
   / RTV 900 Diesel Question #1
chado613
Kingston, Ontario, Canada
IH 624, IH B414, Kubota RTV 900, Kubota M7060
Hi Guys,
I just stumbled across this site and cannot believe I have not seen it before!
I have a question I hope to get some advice on:
Occasionally when starting the (diesel)Kubota, It will start and rev extremely high right away and shut itself off. It will then have to sit for 5-10 mins and then will usually start right up
Look forward to being a part of these boards!!
Thanks
Chad
So far my research suggests maybe fuel filter, bad nozzles or fuel pump
So I replaced the fuel filter on the weekend and I went out to start it up this morning, the following happened:
1. Glow the plugs for 25 seconds
2. Started it up
3. Began revving higher and higher
4. Tons of dark grey smoke was coming out of the exhaust
5. I turned the key to the off position
6. The engine kept running hard even with the key off
7. eventually after 20-30 seconds it began to rev down and shut it self off
This only happens when starting the machine cold, It does have a block heater and if plugged it starts fine. Last winter though the machine never did this. I am worried this will lead to a future (larger) problem(s).
I am not sure what the heck is going on here and if anyone has had previous experience with something like this I would love to hear from them.
   / RTV 900 Diesel Question #4
How many hours on your machine.
When people mix gas into diesel engines they sometimes rev uncontrollably.
The smoke would indicate a possible head gasket leak.
Just some thoughts.
   / RTV 900 Diesel Question #5
I would drain all the fuel out of the tank and replace with fresh fuel that you are sure is clean and fresh diesel.
Caterpillar 330FL (A50120)
Caterpillar 330FL...
2004 Mercedes Benz E-Class Sedan (A50324)
2004 Mercedes Benz...
Generac 2000 Generator (A50774)
Generac 2000...
KUBOTA M7-132 (A53084)
