rtv 900 broken parts
   / rtv 900 broken parts #1
biodiesel1
Halifax, Nova Scotia
Toro 4235
i have a two month old Rtv 900 with 128 hrs. So far under warranty the dealer has replaced my front elec/hydro lift cylinder for my plow, my heater motor burnt up for the cab heat, the tale pipe has fallen off and lost it in a snow bank so I have a brand new exhaust and the last storm I broke my front right axle. Will the problems stop?Has anyone had the same issues?
   / rtv 900 broken parts #3
Foggy gauges. Repalced, and just another one started fogging.
-Mike Z. /forums/images/graemlins/grin.gif
   / rtv 900 broken parts #5
biodiesel,
Sounds like most of your issues have been related to accessories and not the RTV itself. The tail pipe sounds like the issue that was part of a campaign Kubota had. Sounds like the word didn't reach you.
Did Kubota say whether they believe the plow setup (or plowing itself) was the cause of your broken axle?
   / rtv 900 broken parts #6
60 hours and tailpipe issue also. Fixed by dealer.
Dash cracked and fogged up guages. Replaced also.
Lots of irritating rattles which I am isolatiing and fixing.
Initial steering noises, which went away on its own.
Common shifting issues which is somewhat getting better.
Overall to this point we are satisfied with the machine. Work duty performance is better than expected. Fun factor is less than we expected, more to do with restrictions to trail systems due to width of unit.
19200 (A50324)
19200 (A50324)
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
