RTV 900 Aux. Control Valve
   / RTV 900 Aux. Control Valve #1
engineer
Washington County - Upstate New York
L3710, BX 2200, Pac-Trac PT-2400
Does anybody know the operating pressure and flow volume of the Aux. Control Valve for the RTV? Have been considering an RTV, I will have easier time justifying the expense if it can have a greater utilitarian purpose than just for shear enjoyment. Would it operate a wood splitter and/or a hydro saw?
Thanks in advance,
Engineer
   / RTV 900 Aux. Control Valve #2
I forget the exact numbers, flow was about 6 gal/min. ALot more than I expected. It will run a wood splitter or hyd saw fine. Infact Kubota will be comming out with their own eventualy.
   / RTV 900 Aux. Control Valve #3
Kubota's remote hydraulic valve flow rate of 5.7 GPM (6.2 GPM Max) and Maximum Working Pressure 2990 PSI.
   / RTV 900 Aux. Control Valve #4
Are you talking about the option listed at http://www.kubota.com/f/products/RTVSpecs.pdf as the Auxiliary remote valve? Can you just use the hydraulics on the worksite machine to run implements or do you have to pony up for the auxiliary valve?
Brad
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
12' CONTAINER (A51248)
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
