Price Check RTV 500 Snow Blade
   / RTV 500 Snow Blade #1
taxman80
Norwich, Ohio
BX2350
Has anyone bought a snow blade for their RTV 500? What is a good price? Did you also install the heavy duty front struts?
   / RTV 500 Snow Blade #2
I bought the factory set up for my 500 when I had it..Not sure, but I think it was around $1200. You do need the heavy struts, the plow is very heavy.
Check the Kubota site under build My Kubota...All of the MSRP's are there.
   / RTV 500 Snow Blade #3
I'm probably a little late on this one, I don't know how I missed it before.:ashamed:
I installed the American Eagle 60" plow system this year. Cost was about $600 for the state plow design like I purchased, a straight plow was approx. $100 cheaper at the time. It istalls using the 4 holes in front where the 2" receiver hitch is and you drill 4- 3/8" holes up from underneath to bolt through as well. It appears to be a well built unit and the lift height is very high. To use this plow you need a winch or you have to purchase a hydraulic lift set up. Since I already had a winch this was much cheaper than the factory plow option. I've heard very good things about American Eagle products, from all the reports I read if you have a problem they are very good about taking care of it.
I didn't install the heavy duty struts, I can't see a need. The plow squats the front a little but it doesn't really make much difference from what I can tell.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
