Rtv 500 not starting?
   / Rtv 500 not starting? #1
Got a 500 that if it sits for a hour or so it will not crank. It will turn over but does fire. This has happened twice. After a while it will start up. Any idea what could cause this? I've loosened the gas cap no change. Both times it has been sitting in sun during middle of the day.
   / Rtv 500 not starting? #2
Cranks but won't fire. Sounds like fuel shortage..
Check fuel lines for any debris that restricts fuel flow.
May take some detective work to track down the cause... checking off one thing at a time.
   / Rtv 500 not starting? #3
When it finally does start, is there black smoke? Meaning it is way rich? I have seen this happen with a slight leak in the carburetor inlet needle/seat. Since the RTVs are injected (I think), you may still be having this problem if an injector nozzle is slowly leaking down after it is shut off.
   / Rtv 500 not starting? #4
I had your exact problem with my RTV500.
Seemed like fuel vapor lock, but vapor lock is a carb problem and the RTV500 is fuel injected.
Kubota mechanic was skeptical when I described the problem. He confirmed the same problem next day.
He cleaned out the fuel tank, put on a new fuel pump and suggested I use '0' methanohol marine gas, which I do now. No problem since.
dont see any black smoke. may drain gas tank and put in non ethanol see how it does. the funny things is each time it has happened it been sitting out in the sun and seems like something getting hot, but not sure what. but it still cranks a little later and it not moved out of sun.
   / Rtv 500 not starting? #6
buck
You can eliminate the "sun" variable by parking it in the shade..
   / Rtv 500 not starting? #7
My 500 runs perfect on E10 fuel, so I don't think that's the problem...
SR
tried to get issue to happen yesterday with no luck. hard to look for a problem if it want occur. is there a fuel tank drain? i was tracing out the fuel lines and see the carbon box and tried looking up some info on it but very little out there guess I can just take one line off at a time? has anyboyd ever pulled the fuel pump out, looks like not that easy due to location.
wouldnt start again yesterday. got to troubleshooting and did not have fuel. looks like the fuel filter is plugged up. took fuel pump and off ran in a cup of gas and pumps great. calling to try to see if you can only get fuel filter today. once again this happened with it sitting in sun but now just know that it is coincidence.
   / Rtv 500 not starting? #10
Sounds like you at least found the problem. Good luck.
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
2018 Jeep Grand Cherokee Multipurpose Vehicle (MPV) (A51694)
2018 Jeep Grand...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2003 John Deere 4X2 Gator (A50121)
2003 John Deere...
CFG Industrial MX20R (A50121)
CFG Industrial...
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
