RTV 1140 Rear drive issue
   / RTV 1140 Rear drive issue #31
Any update on your drive issue???
   / RTV 1140 Rear drive issue #32
help my kubota wont move in 2 wheel drive drive shaft is ok linkage is ok what next
   / RTV 1140 Rear drive issue #33
Need more information...
does it move in 4 wheel drive
It should move in low, medium or high range... are all ranges immobile?
Have you checked the linkage to the transmission under the lift bed to make sure it is connected to the shift lever
have you checked the hydraulic fluid
is the brake on
I haven't been on in awhile and forgot I had posted this :-/
Update: We were so Blessed to have the KTAC insurance! It turns out a t-post (obviously one lying on the ground that shouldn't have been there) was leveraged up by one of the front tires and rammed up through the frame of the RTV. It knocked a hole in the transmission :eek:uch: I can't believe it didn't immediately lose all the fluids and quit completely. The t-post even damaged some of the gears inside the transmission.
Bottom line: Kubota KTAC took care of every expense to the tune of well over $8,000 :thumbsup:
Terry
   / RTV 1140 Rear drive issue #35
OMG!!!!
What an amazing outcome...I would never have guessed that a T post would have been the culprit.
Hooray for KTAC.
TROY BILT GAS POWERED POWER WASHER (A58374)
TROY BILT GAS...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
MASSEY FERGUSON 275 TRACTOR (A58375)
MASSEY FERGUSON...
