rtv 1100 overheating problem
/ rtv 1100 overheating problem #21
went hunting on dusty roads this past week...had to wash my RTV 1140 radiator out with hose...dust clogged the radiator and temp started rising...had to do twice...radiator is in dust trail, thus gets clogged under extreme conditions...easy to wash out with hose.
as of now my 1100 is in the shop. After monitiring coolant level to make sure its dropping I've taken it in. at first the dealer said they let it run, tightened up all clamps and lied about putting an air test on it in hopes I came and picked it up. lol.
They now are in communication with the kubota tech hotline going through the motions. Theyve had to order the proper stantz test fitting for cooling system test, buy a new compression tester cause the one they had only went to 260lb and roll up their sleeves. Kubota really needs to do quality control with their dealers. Ill keep my nightmare updated here in hopes it helps someone else.
/ rtv 1100 overheating problem #23
So your losing coolant?
/ rtv 1100 overheating problem #25
A 2 gallon pump up garden sprayer works great to wash out a radiator on the trail. I just keep one full of water in the back, during the dusty parts of the summer.
Have you done a pressure test? Or see bubbles at the radiator cap spoat?
It's at the dealer.it only has 75hr on it, and I'm tired of doing kubotas troubleshooting.
/ rtv 1100 overheating problem #28
You shouldn't have too. Good luck, hope it works out for you.
/ rtv 1100 overheating problem #30
Your the guy with the M59 and hyd. problems. What a bummer, sorry for you to have been dealt 2 crappy Kubotas. All I can say is sorry from a loyal Kubota owner and someone who has many Kubota products including an RTV1100. I have never seen my temp fluctuate, ever. Rarely do I hear my fan come on, only in summer when hot and extended use. Good luck.
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2023 Deere 317G (A60462)
2023 Deere 317G...
John Deere 3025E (A53317)
John Deere 3025E...
30KW GENERATOR (A58214)
30KW GENERATOR...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
