RPM up and down B7500 ?
   / RPM up and down B7500 ? #11
As leonz pointed out, you can get some intermittent crap sloshing around in your tank. I used some HEET (for diesels) and some fuel additive to clear up an intermittent problem with my old BX2200.
leonz and others have helped me out on these issues often.
Thanks . I put some diesel fuel stabilizer ( CRC Brand ) and some Lucas fuel system cleaner when ever I fill the can up .
That theory make sense though about something sloshing around in there . It could be a stink bug we ( North East ) are infested with them right now and they can squeeze into some tight spots :eek:
Appreciate everyones help
Okay . I changed the fuel filter this weekend and my problem persist . Even with the tractor stopped on level ground the rpm's will drop below 1000 from where I have it set at around 2000 . It will sputter for a couple of seconds then start to rise back up .
My fuel is about a month old with a CRC water additive and some Lucas fuel treatment .
Should I drain the tank ? Is it possible the Air filter ( about 30 hours old and I just blew it out when I changed the fuel filter ) .
Thanks
So this is what's happing . I pulled the full line from the tank to the filter and got good flow . The tractor is using more fuel that what is being fed to the filter at high RPM 2000 or above I can watch the fuel level go to 1/4 inch above the bottom of the filter and it will start to sputter once the level is below the bottom of the filter .
Is there a screen in the bottom of the tank ? could it be the fuel pump ?
thanks
   / RPM up and down B7500 ? #15
The screen is in the bottom of the tank.
The chances are the fuel line is either
plugged and or collapsing.
The issue is the fuel inlet in the tank; if the
tank has a bottom draw the tank has to come
off to clean it and replace the fuel line to the
injection pump.
The inlet screen may be gone and you are
sucking it all in the fuel ine.
Does the tank still have the fuel filler sreen
basket in the filler neck?
I must suggest to you to replace the air filter
as you may have put a pin hole in it when you
blew it out.
You can eliminate the screen and uses a larger
fuel delivery hose by installing a Racor model
1100 fuel filter(5 micron filtration) unit to
eliminate the issue with junk in the fuel
tank and water as it will spin the dirt and
water out of the fuel for you with the suction
of the fuel pump.
Thanks for the info leonz . I pulled the fuel line off from the bottom of the tank to the full filter and the tractor seems to be running better ( maybe it had some air between the fuel line and the filter housing ? ) . If the problem persist I will follow your advice .
Thanks for your help
2019 KENWORTH T680 SLEEPER (A51222)
2019 KENWORTH T680...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A51039)
New Lewis Brothers...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
2019 TAEKUCHI TL8 SKID STEER (A51242)
2019 TAEKUCHI TL8...
