rpm range
   / rpm range #1
k wade
what would be the safe operating range for a satoh bull 2 cyl, diesil
   / rpm range #2
since Diesel engines are built with a governor, its safe to say it probably wont overrev.
I usually run mine from between half and 3/4 speed, whatever it is rated at.
ie my D2000 will hit 2500 rpm, max engine speed but I usually kep it between 1500 and 2000 rpm.
   / rpm range #3
If it working hard run it at near maximum RPM. Peak HP is near the top of the RPM range. You don't want to lug it at low RPM's. For easy work it doesn't matter so much.
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
Ford Tractor (A50120)
72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
72in Dual Cylinder...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
