has anybody tried using a winch for a three point hitch for lifting the implement.my case tractor does not have a 3 point set up and I don't know to find the item needed to change mine over. I have a case210b tractor
Conversion kits to change Pre-Ferguson 3-Pt Hitch tractors TO a Ferguson Industry Standard 3-Pt Hitch are still available:
DESIGNED AND MANUFACTURED IN THE USA BY
REDLANDHILL.
THIS IS A UNIVERSAL 3 POINT HITCH SYSTEM IN CAT 1 SIZING.
THIS IS COMPATIBLE WITH ANY CAT 1 3 POINT HITCH IMPLEMENT. IF YOU HAVE AN OLDER
TRACTOR THAT DID NOT COME WITH A FACTORY 3 POINT SYSTEM THIS IS WHAT YOU
NEED TO PUT IT TO WORK USING ANY OF THE DOZENS OF CAT 1 3 POINT IMPLEMENTS THAT CAN
BE FOUND EVERYWHERE.
