Rototiller sized for 25hp tractor
   / Rototiller sized for 25hp tractor #11
problem with buying a rototiller that was only as wide as rear tires....is when you buy a larger tractor and suddenly your $3000 tiller is too small. i honestly dont see any issue in running a larger tiller, just slow down.
   / Rototiller sized for 25hp tractor #12
If its a good deal buy it. Try it out... if its not for you should be a easy sell in the spring
   / Rototiller sized for 25hp tractor #13
I run a 50" John Deere 550 tiller with 6 tines per flange on my 1025R. It should be about the same HP but a bit smaller in size. In the dry (summer time) I could probably run a wider one. In the wet and damp (spring time) I have to be careful not to stall. In the wet and damp I have to be in 4WD and low gear or it will push so hard I can't hold it back. I don't think I would want a bigger one personally.
   / Rototiller sized for 25hp tractor #14
Used tillers hold their value. Try it, if you dont like it sell it.
But personally I think you will be just fine.
We use a 5' tiller behind a 2320 deere with no issues. 18 pto HP
   / Rototiller sized for 25hp tractor #15
I run a 60" King Kutter on my 27hp tractor. Tills awesome. We have rocky soil and it spits out softball size rocks all day long. I go slow and have no issues. I till gardens each year and have done large areas for replanting grass.
   / Rototiller sized for 25hp tractor #16
I agree the 25 hp is not big enough to handle that big of rototiller. I used a 5’ on my 30 hp, does ok after I subsoil first, I have a 48” that is perfect, but several years ago the gearbox went out, a guy messed up box so can’t replace gears need whole gear box, I found one that that cost about 625 , so I haven’t replaced it.
BOX BLADE (A58214)
BOX BLADE (A58214)
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
gravely riding mower (A55758)
gravely riding...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
UNUSED FUTURE 32"...
