Tiller Roto tillers forward rotation or reverse?
   / Roto tillers forward rotation or reverse? #1
Flatbroke
North Central Montana
Massey Ferguson 4610
They can come either way which is the best type for a garden and some pasture renovation? I have fed cows on the spot and there is a lot of manure to incorporate as well as lots of old hay that was tramped on. It should add some nice stuff to the soil. I plan on a 84 inch slip clutch pto model either way pulled with 80HP at the PTO. Opinions please?
Gary
   / Roto tillers forward rotation or reverse? #2
Watching the video of reverse tiller vs forward tiller, the reverse tiller seems to incorporate top vegetation more. I have a forward tiller and it does a good job, at least for me and it climbs over rocks and other debris rather than bind up or break a tine.
I recently used mine to make a fire break after a pasture fire got out of control and even running very fast, it broke up the sod better than a disk would have, walked over small pine trees (2-3" diameter) and chopped them up. I am happy with my forward rotation tiller and it is much cheaper than a reverse rotation one.
I had planned use for only doing a small garden so making multiple passes to mix everything up well is not a big deal. Could a reverse rotation tiller do it in one pass, perhaps, perhaps not, but it's not a big deal to make 2 or even 3 passes. I used mine to till up my neighbors garden that had about 8" of leaves piled on it for adding organic matter. After 2 passes it looked pretty good but after 3 it had chopped everything up well and incorporated it nicely.
If you are doing acres and acres of tilling having to do multiple passes might be objectionable, but for small garden plots, it will be lifetime before I spend enough to justify the extra cost of a reverse rotation tiller.
   / Roto tillers forward rotation or reverse? #3
One more thing, if doing a pasture, I wouldn't think you would want to kill the grass by burying it with a reverse rotation tiller. A forward tiller will mix manure and straw in nicely and still leave some grass on top to re-emerge.
   / Roto tillers forward rotation or reverse? #4
Gary
We stock a 7 ft Tarter tiller that will run forward or reverse for $2495 + shipping. Ken Sweet
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2021 John Deere R4038 (A53485)
2021 John Deere...
2006 JLG 2030ES 20ft Electric Scissor Lift (A55851)
2006 JLG 2030ES...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
