Rotella 5/40 synthetic
   / Rotella 5/40 synthetic #1
BBELL
Bronze Member
Maine
Kubota L-4310 GST/ 1979 Ford 1700
I just put Rotella 5/40 weight, that's the only weight I could get. Is it ok, or is the 5 weight to low?
   / Rotella 5/40 synthetic #2
I'm running it in both of my diesels. Great cold weather starting. At running temps it's a 40 weight. You're fine.
   / Rotella 5/40 synthetic #3
Based on the pour point (-40 C). unless it get close to -20, you would be fine. It depends on how far into Maine you are. Might be good, might not be. If you use a block heater you are fine.
I know in my part of Taxachusetts we see up to -10 below & colder in some parts. For me Rotella (a dino oil), would not work to well since you are getting close to the boarder line pumping temp.
I have block heater but never use it since I never remember. For me, you should not need one unless you livewhere the temps are so low...you get the point.
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2009 John Deere 1050J Crawler Tractor Dozer (A52377)
2009 John Deere...
