ROTELLA® ELC antifreeze
   / ROTELLA® ELC antifreeze #1
eno
PBG, FL
BX2200
Planning on using this on my BX. good or bad idea. thanks /forums/images/graemlins/confused.gif
   / ROTELLA® ELC antifreeze #2
good coolant but what do you plan to gain by it? You will also need to flush the old stuff since it is not compatible with the current EG coolant in your BX.
It contains no silicate etc, which is good but your BX does not even need SCA anyways.
I see no benefit but that is me. Just use a Normal Diesel low silicate coolant conforming to thje proper specs and you will be fine.
   / ROTELLA® ELC antifreeze #3
What would be your recommendation for one or more that would be better?????
   / ROTELLA® ELC antifreeze #4
using the search function, I have commented on this many times.
Here is one
LINKER
but some coolants that are fine (for diesel apps):
Prestone Heavy Duty Antifreeze Coolant:
Fleetrite:
Peak Fleet Charge Antifreeze:
Fleetguard Compleat:
Caterpillar DEAC: (Diesel Engine Antifreeze Coolant)
I use the fleetrite in my GSXR1100 since new, works great...Clean as mile 00000
Also Evans coolant is NOT a good choice, based on what I have read.
   / ROTELLA® ELC antifreeze #5
I am going to use Chevron Delo ELC .supposed to last three years ,which will be more than ample for a two year change. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  • 707062-Delo ELC.pdf
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2018 Generac S/A Towable Light Tower (A52377)
2018 Generac S/A...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
