Tires Rotating rear tires on TC24DA to get wider base
   / Rotating rear tires on TC24DA to get wider base #1
PatC
S. MS
TC24DA
Was asked this weekend why I had not reversed my rear tires. Said this would give me a wider base. Swapping left to right etc. Has anyone done this on a 24? Why or why not?
   / Rotating rear tires on TC24DA to get wider base #2
I did it on my TC18. It increased the width by about 4 inches. Four inches doesn't sound like much, but it does feel a little more stable on hillsides.
Solo
   / Rotating rear tires on TC24DA to get wider base #3
I did it to my TC-30 and it sure feels much more stable. Eases my "pucker factor" by several points too.
   / Rotating rear tires on TC24DA to get wider base #4
In the manual for my TC24D, it says the rears can be dished in or dished out to adjust the width, but with the wide turfs on my machine, the widest setting (dished in) is the only way they can be mounted. I tried switching them just out of curiosity, and it can't be done. So in my case, they were already set for a wider wheel base. If yours is not, give it a try. Other than fitting between trees or covering your tracks with a mower or blade, I can't imagine why you wouldn't want the wider setting for stability.
Brad
2014 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2014 POLAR TANK...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
1994 International 3800 Bus (A54814)
1994 International...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
2025 SF60 60in Hydraulic Forks and Frame Skid Steer Attachment (A56857)
2025 SF60 60in...
