Tires Rotating rear tires on TC24DA to get wider base
   / Rotating rear tires on TC24DA to get wider base #1
PatC
S. MS
TC24DA
Was asked this weekend why I had not reversed my rear tires. Said this would give me a wider base. Swapping left to right etc. Has anyone done this on a 24? Why or why not?
   / Rotating rear tires on TC24DA to get wider base #2
I did it on my TC18. It increased the width by about 4 inches. Four inches doesn't sound like much, but it does feel a little more stable on hillsides.
Solo
   / Rotating rear tires on TC24DA to get wider base #3
I did it to my TC-30 and it sure feels much more stable. Eases my "pucker factor" by several points too.
   / Rotating rear tires on TC24DA to get wider base #4
In the manual for my TC24D, it says the rears can be dished in or dished out to adjust the width, but with the wide turfs on my machine, the widest setting (dished in) is the only way they can be mounted. I tried switching them just out of curiosity, and it can't be done. So in my case, they were already set for a wider wheel base. If yours is not, give it a try. Other than fitting between trees or covering your tracks with a mower or blade, I can't imagine why you wouldn't want the wider setting for stability.
Brad
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
JOHN DEERE 4840 TRACTOR (A51243)
JOHN DEERE 4840...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
2005 Wilson Hopper Bottom Trailer (A50514)
2005 Wilson Hopper...
Vermeer 630A Stump Grinder (A50515)
Vermeer 630A Stump...
